0 Members and 6 Guests are viewing this topic. Read 385910 times.
Three guys in our local audio club use ANK DACs: two 5.1 Signature and a 2.1. I was predisposed to not like the ANK DACs, a lot of money for a DAC that doesn't really do hi-res (24bit/96kHz) but I have to admit it is a very, very nice DAC. I use a HoloAudio May KTE, one of these years I would like to compare the two DACs.I recently heard the ANK 2.1. We switched between vinyl and CDs (no streaming) and honestly, without looking, I wouldn't be able to tell what source was playing.The turntable is excellent so the ANK 2.1 acquitted itself very well.
What phonostage was used?
Hi Viggen,Please describe sound of the ES9038Q2M sabre dac in greater detail and how it compares to other dacs.Thanks,Alfi
A friend whose ear I trust is raving about the Topping E70 Velvet AK4499EX. Currently $381.65 at Amazon. No personal experience here, but if I were currently in the market for a DAC, I'd certainly give it a shot. No need to look for an outboard PS either...
Although, recently, I am using this dac more than the 1543:https://www.aliexpress.us/item/3256805660696598.html?spm=a2g0o.order_list.order_list_main.21.54441802h0d6Gv&gatewayAdapt=glo2usaIt's a sabre chip dac which I hate with a passion. But, this dac sounds good. I am using i2s connection between it and the ddc mentioned above.
Built-in OCXO and discrete class A output filter, all for $120. Fascinating. May have to get one.Edit: Turns out this dac was designed by a longtime member on diyaudio. So some credibility there. He also has/had an r2r dac and a USB/I2S converter called 'UAC1' which is also on aliexpress.
Yup I am using UAC1's i2s output to the dac. I just ordered these:https://www.aliexpress.us/item/3256805855753827.html?spm=a2g0o.order_list.order_list_main.11.21ef1802HjHCDe&gatewayAdapt=glo2usahttps://www.aliexpress.us/item/3256805584176583.html?spm=a2g0o.order_list.order_list_main.17.21ef1802HjHCDe&gatewayAdapt=glo2usaI tracked the seller to diyaudio too. UAC1 is the first product I got from this seller. Better than Singxer SU6, Denafrips Iris and Matrix XSPDIF2. So, started buying his other products.
Do you have more info or links on the UAC1? Not much I can find with google.
"Air swirling around you"? Can you elaborate? Is that a good thing?
Is there a difference between these two other than the name UAC1 and UAC-1. And what power supply are you using?https://world.taobao.com/item/681228697041.htm?spm=a21wu.11804641-tw.shop-content.15.4617718caTZX5hhttps://world.taobao.com/item/695632033271.htm?spm=a21wu.11804641-tw.shop-content.18.4617718cKxl3HA
they are the same and I am using HDPLEX300's 9v output. the one i ordered is the one in wushuling's post above. however, the one i received didn't have a clock input. so, i had to order a difference one to get the clock input:https://www.aliexpress.us/item/3256805855753827.html?spm=a2g0o.order_list.order_list_main.11.21ef1802HNY9r8&gatewayAdapt=glo2usa
