It's been about a month since the SI384 DDC and the accompanying -100hz clock arrived. With the dacs I have on hand, I actually prefer the UAC1 DDC. The SI384 exhibits a more studio quality sound. With each dac I tried, there's more space/air/detail and such. But, the UAC1 sounds more musical to me. Then, I found a Pontus mk1 on audiomart and the seller is very local to me. So, wtheck might as well try it out. I did previously own a Pontus mk2 but didn't like it but that when I had the Singxer SU6 and didn't appreciate the lack of longer term listenability. First, I plugged in the Pontus to the UAC1 via RCA/SPDIF. It didn't sound annoying compared to the previous Pontus but it sounded kind of boring. The Pontus 2 had a huge sound to it but its fake N/OS sound was hurting my ears after 10 minutes. With this, it has long term listenability but lacks the charm of my other dacs when connected to the UAC1. So, the UAC1 has an i2s output. I thought what's the chance that they are actually compatible. Well, they are compatible.With i2s, the sound changed slightly. Cleaner in a good way. Slightly raised soundstage and less background noise. But, only marginal improvement. Then, I plugged the Pontus into the SI384. The SI384 actually made a bigger improvement on the Pontus than the UAC1 did. And, weirdly, it didn't improvement the sound by making it more audiophile sounding. It's actually very listenable and even a bit charming.Overall, I think SI384 is a bargain in terms of matching it up with your pre-existing Denafrips. But, in terms of dac/ddc, I think I still prefer the UAC1/TDA1543 dac. The sound has more character. And, it's so small and diminutive on the hifi stand. But, this is with the HDPLEX300 powering the pair. If using lesser PSU, the SI384/Pontus probably sounds better if memory of my listening experience sans HDPLEX300 is correct.
Well kiss my grits. This little cheap azz R2R arrived today. Much smaller than I expected, too and looking basic AF. Takes 18-24v, so I plugged in my bench supply and connected a cheap USB/SPDIF converter. Hot damn. This $40 box sounds *good*. Really good. No, really really good. Anita Baker's voice has tactility and sweet emotion. Piano notes have a kind of naturalness and weight I don't normally hear with the usual dacs, not even my modded Soekris 1021. Transients have snap, even snappier than the Topping E50 (not E30) I wrote about recently. Very dynamic. Organic, realistic bass punch, but not overwhelming. Not syrupy or rolled off, though like the Muse TPA1543 I once had (and an AC'er borrowed and never returned ). Very good extension. Has that R2R organicy, natural presentation. Surprisingly comes off as very quiet to me. Microdetails also pretty decent.I'm not even going to compare it with the other Peanut DACs. It's a step or two above them easily. Instead I'll compare to pricier 'budget' fare I've heard/owned. Closest in sound signature is probably the $270 Topping E50, which has a similar toe-tapping quality. But the E50 doesn't have the naturalness of tone and midrange as this PCM56 and isn't as dynamic. The ~ $400Sabaj A20d has better instrument separation, more precise image, overall better extension in the extremes, but again not as good in natural tone/timbre/PRaT. The Soekris also has better separation, imaging, and a bit more dimensionality overall but the PCM56 I think wins on midrange and tone. The Soekris has always had a great sense of space but a little bit thin in the mids. This little black box is the opposite. They definitely share a similar organic, textured delivery. I wish I had my 2 channel setup running because I would love to compare the two through some good speakers. Alas my HD6XXs must suffice for now and with my headphones I think the two are *maybe* evenly matched just a question of tradeoffs. Will have to really spend time to compare. But I mean, my Soekris runs on LT3045 regulators and LifePo batteries. This little black box shouldn't even be in the ring.'The last shall be first and the first shall be last'.To say my expectations were low is an understatement. I bought this dac on a lark just to get a little 'vintage' R2R flavor in the peanut mix. Also as much as I like to mess around with cheap dacs I am ready to tackle another new higher end project like the Soekris. My intent was to get one of Soekris' newer boards and go all out, but I may have to consider some other projects based around these old R2R/Multibit chips...
welcome to the thunderdome! these cheap and ancient r2r dacs when fed by ddc and lpsu sound amazing. i did have the su6 and matrix xspdif2 but prefer the cheap UAC1 i got off ali. i've tried various chip based dacs in the past year from 1704, pcm63, CS6xxx, 1543 amongst others and 1543 is my fave thus far. i did try a 1541 dac before but that was before i discovered the wonders of ddcs on r2r dacs.i do see this pcm56 dac on ali and your post got me curious:https://www.aliexpress.us/item/3256806892894197.html?spm=a2g0o.productlist.main.1.16ca1f71bVoOd0&algo_pvid=0f3dc576-3ea1-4cb8-9ee7-c84847907f72&algo_exp_id=0f3dc576-3ea1-4cb8-9ee7-c84847907f72-0&pdp_npi=4%40dis%21USD%2123.52%2119.76%21%21%2123.52%2119.76%21%402101e9a217262318142777882e265d%2112000039331604699%21sea%21US%214349778353%21X&curPageLogUid=6y5kz95IE7SK&utparam-url=scene%3Asearch%7Cquery_from%3A
the UAC1 is pnp with my pc but it does have a proprietary "million" usb driver. were you able to use the uac1 at all? will be curious to see how you stack it against your other ddcs. i also have the other "million" ddc with the external clock which i think you have already read. that one uses a more standard amanero usb driver. i think i would prefer this over the su6 but still prefer the uac1 over both.i like how the cheap $20 dac has all the interface in the back so easier to hide cables.
Call me a very recent fan of the PCM56 as well. In the amazingly cheap DAC category, I'm liking it better the the Phillips Little Giant. In fact at this point, it's got my pricier DAC's looking over their shoulders. Time will tell of course. FWIW, using it with a Swagman 12V LPS.
