0 Members and 1 Guest are viewing this topic. Read 6996 times.
That's a huge drop in sensitivity. An amp will make some small differences, but not even remotely enough to adjust for the entirely new speakers. What were your old speakers? Do you have the option to apply EQ or room corrections somehow?
While it is possible that another amp might add more detail (potential downside: might sound sharp/etched if it leans too far in this direction), the most likely culprit is the sensitivity difference in the speakers. It's possible the SF speakers mask a little information by emphasizing a smooth versus detailed presentation, but sensitivity is probably more the reason. I own 96 dB, 8 ohm speakers, and it wasn't until I moved to high sensitivity speakers that I heard greater nuance/micro-dynamics present in the music. The analogy with low sensitivity speakers is like trying to "move an ocean liner" -- it's just more difficult to move/stop speaker cones when they are heavy and/or less efficient. You can try adding an amp with more power and higher current reserves, but it is still a difficult task, even with more power on-hand. That's why in my search (a separate post) I have focused on the small set of high sensitivity speakers. I would miss the vocal nuances of Billie Holiday and Sarah Vaughan without staying high sensitivity.Sorry to be the bearer of bad news. On the plus side, SF speakers generally sound lovely and musical, so there are some benefits to this change.-dB
Things which can increase detail:Speakers breaking in.. this can take six months unless you just leave them running all day every day. As for breaking in the speakers. just play something loud for a few hours. Orchestral music... Symphonies.. full blast. Your favorite Rock.. See if the details improve. (unless you STAYED in the room, then your ears will also need some time to heal LOL)Power cord.. Even a 'cheap(er) one Shunyata, Pangea come to mind. possible may help, possible no difference. Power conditioner. This is a slippery one. Cheap ones don't 'do' much.better IC from pre to amp, better speaker wires..Also, do you leave the amp on? Try leaving the amp and preamp on overnight, then listen for the details. This may even be the caps in the crossover.. So leaving something on repeat overnight, at very low levels, a whisper with your ear at the speaker, just so power is going through those crossover capacitors and the wiring all through the speakers..
I think one thing for me to try also is playing a piece that i'm familiar with at but at higher volume and seeing if the 'detail' i thought might be missing or more recessed is now more prominent or noticeable.
I find it well worth the $15 a month in increased electric bills to leave everything on 24/7/365.The first hour of listening every time as less than stellar is just not worth the few bucks on my electric bill just leaving them on costs.One part of my equipment I leave off is an Audio Research SP-15 preamp I keep around to use only for it's three tube phono section.Since I only use that maybe once a month for a day, I leave it off. And put up with the hour it takes to sound magical. Same thing for my Sony SCD777ES. I want to make it last 20 years.. So I use it sparingly maybe twice a month for a few hours.So I leave on two power conditioners, the amp, preamp, a second tubed preamp I use as a 'glorified tube buffer' for my DAC, the DAC, a Behringer DEQ2496. a solid state phono box.And a CD changer. these things have been left on nearly all of the last seven years..Yeah it adds to the heat content in Summer, and so adds to the electric for air conditioning.. But it is worth the cost.So I suggest trying leaving the amp preamp on all night and think over if it is worth it to you.I find stuff takes about an hour to sound better, but it really does get even better after a few hours more.Even part time. Like if you know you will listen the next day on a weekend, leave it on. Just shutting it down when you know you can't use it for a few days.
Yes, my experience is that high efficiency speakers tend to provide a more forward/detailed/dynamic presentation. OTOH lower efficiency speakers tend to be more musical/less fatiguing. So how do these two speakers match up to your audio tastes?I'll ask the elephant in the room question: How did it come about that your wife chose your speakers for you?
I looked up these speakers to see what they looked like. You can buy them at Sears!!!!
Umm, no you can't. 'Sears.com' shows just about anything under the sun for sale now because they've nearly bankrupt.
Thx. Consider me informed.
Sonus Faber speakers are laid back, that's how they are voiced and that's how they sound. If you want more details, you'll need a fairly aggressive, forward sounding amp with a lot of power and grunt.
I agree with leaving SS amps on all the time for highest sound quality but don't post in this thread http://www.audiocircle.com/index.php?topic=149400.0 or you'll get an earful on that subject.
