0 Members and 1 Guest are viewing this topic. Read 7003 times.
Sonus Faber speakers are laid back, that's how they are voiced and that's how they sound. If you want more details, you'll need a fairly aggressive, forward sounding amp with a lot of power and grunt.
The Venere break from that traditional SF sound quite a bit actually. Their tone is more in line with my preferences and are my favorite 'listenable' SF. I find the Venere series to be more forward and have a little more sparkle on top (these are different characteristics). I have been told the Olympia III follows this sound signature some as well but have not had the opportunity to hear it yet.As Elizabeth pointed out, you need to give those speakers some time to break in. There is also the possibility that the new system simply does not synergize with the new speakers, but you can't figure that out until the speakers have had enough time to properly work into their 'designed' state.it could also boil down to a completely different presentation and the adjustment is just too much to take in at a single time. Initial observations are often difficult to fully grasp because they generally vary so much from YOUR norm in reproduction.
Try a Burson Cable + Pro between the digital front end and your pre. Price is 199, but I would pay $500+ for this amount of detail.
Theoretical question...would using balanced outputs from a DAC to amp rather unbalanced RCA help offset the lower sensitivity of the speakers? From what I've read, balanced outputs can be as much as 6db more than unbalanced.
Good info...you said it, completely different presentation. I bought the current EMO amps really just to try them out, being pretty inexpensive, but I ended up liking how they worked with the Tektons, the jury is still out whether they're right for the Veneres
I experienced a decrease in resolution with the Burson Cable+, so personally it would not be an option I'd consider before I've explored other options.
Interesting that some claim - after hearing dozens of high end cables - the Burson Cable+/Cable+ Pro is the finest they've ever heard while others find it to be mediocre at best. I know these different reviewers are sincere and honest and took the time to report their findings. Is our individual hearing so different? Is it a matter of taste/preference? Just curious.
I believe (not having heard Tekton) that you may have more transparent speakers now and there might be something with the Emotiva amps they are exposing. One of my favorite products is the Dayens Ampino integrated. While it is a stellar little amp, generally the more high end the speaker gets, the more you realize its shortcomings. It isn't a slap on the amp - it just is what it is. Nobody would ever expect a $500 integrated to beat those costing 5-10 times, but it can hang with them toe to toe as long as the speaker doesn't completely outclass the amp.With any new speaker purchase, you are likely going to have to go through the entire 'synergy' spectrum again. You cannot compare a speaker to a speaker, or any component to a component because their applications, strengths, and weaknesses may vary greatly. It is the system as a whole you have to compare and you don't have your Venere system dialed in yet.
Another question, at risk of sparking debate, in general is better to bi-wire or is the concencus that it makes no difference?
Go to Audiogon and get yourself a pair of Clear Day solid silver speaker cables. Paul has a 30 day money back guarantee and the cables are inexpensive. I had a good long chat with him and have a pair heading my way this week.
I've just received a pair for review and frankly, I think Armaegis may have just gotten a bad pair. They sound fine. (I'll be posting a review in a couple of days.) [/font][/size]
