0 Members and 1 Guest are viewing this topic. Read 8206 times.
Nathan,Are you saying that the new products' frequency response depends on distance to the wall's surface? If so, do you tell people how to figure out what distance to use?
George,How did you make your links so small?
Ha! It worked. (There's no way I'm going to remember how to do that, though. I better work on this soon, before I forget.)
George, mostly true. I said the frames probably won't fix your problem as you were experienceing an extreme hump at 80 Hz, but they will certainly have an impact. I would rather be conservative in my claims and have the customer be pleasantly surprised than the inverse.The newer products are much more effective at lower frequencies, and are thinner. Based on placement and distance from the product to the wall surface, you can achieve better bass absorption than you would be able to calculate using th ...
How do you know they're effective? I can't find any data on what they do (i.e., in terms of performance) on the Echobusters website. Plus, they seem to be priced at about what the Real Traps stuff is (not sure about Eigth Nerve stuff). Moreover, they seem to be pretty darn close to the same size as the Real Traps stuff. Personally, I wouldn't buy these over Real Traps, because at least Real Traps gives you data about their products.
You can always wait, ususally it pays off. The previous 8th Nerve products cost about 1/7th of the Real Trap to get the room packs of each. The visual impact factor of the 8th Nerve stuff is also about 1/7th as much as the Real Traps. In a small room you may not have enough free wall or corner space to mount a full room pack of panels.
