0 Members and 1 Guest are viewing this topic. Read 8205 times.
For christmas I was looking to get some acoustic treatment for my small room. My budget is around $800. I hear realtraps are really nice, but they are huge and heavy. Is there any smaller alternative to them? Whats the next best thing basically?Thanks
I'd highly recommend a conversation with Nathan at 8th Nerve. The new series they have coming out should be amazing. It should be coming out as we speak, and I understand it's patent pending. Sounds exciting, and I know I am going ot try them as soon as I can. I currently have my room treated with the first gen 8th Nerve products, and I can't imagine it being better. It's the best I've used.
B,I use the 8thNerve stuff for HF, but it can't do anything at lower frequencies. Maybe the new stuff will, but the old stuff definitely didn't.George
Should 3" or 4" foam be used and where is it best placed (How far off the ground, along the side walls only,corners?)? Joe M.
G:I dunno man, adding the frames to my corners solved my small bass hump. But from what I hear about the new stuff, the principal is a bit different, and it should be much more flexible at addressing problem frequencies. I know the Room Pack physically can't do much for bass, but the frames do. But Nathan is discontinuing the frames b/c the new stuff is supposed to just kill the frames as far as functionality.I can easily see how you could have a bass problem with those behemoths, but my speakers don't put out a ton of bass, so I can't relate.
There's a guy that comes to some of our meetings in NC, and his entire room is foam. He lives in a cocoon of thick foam with no reflections. I've been inside an anechoic chamber, and I can't say I liked it one bit. I think foam is horrible. Especially used in mass quantities.
Just curious, what does the pattern do (besides looking cool)?
But seriously, not knocking 8thNerve, but based on the laws of physics, the Frames can't do anything for low bass. Your hump must have been mid or upper bass. When I talked to Nathan, he told me his frames weren't going to help below 80Hz where I was having some big issues.George
