SP-3 USB Upgrade Options
0 Members and 1 Guest are viewing this topic. Read 5944 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 19 May 2017, 06:41 pm »
SUBJECT: Bryston SP3 USB Upgrade
May, 2017
Hi Folks,
We are pleased to announce a “Factory”  USB upgrade for our Bryston SP-3 Surround Processor.
The current USB module supports STEREO PCM 48K/16BIT resolution.
The new USB module will support PCM 192/24 as well as DSD Native/64/128.
There are a few options depending on which main board your SP3 has and your requirement for PCM or DSD digital playback.
1.   SP-3 with version 2 - 3 - 4 or 5 main circuit board can upgrade to STEREO plus SURROUND MODES PCM 192/24 ONLY for $600
2.   SP-3 with version 2 - 3 or 4 main board can upgrade to STEREO plus SURROUND MODES PCM 192/24 as well as STEREO DSD for $1000
3.   SP-3 with version 5 main board can upgrade to STEREO plus SURROUND MODES PCM 192/24 as well as STEREO plus SURROUND MODES DSD for $600
4.   SP-3 with version 2/3 or 4 main board replaced with version 5 main board can be upgrade to STEREO plus SURROUND MODES PCM 192/24 as well as STEREO plus
        SURROUND MODES DSD for $1500
SP-3 Main Board     PCM Listening Modes       DSD Listening Modes
2 or 3 or 4 Version   2.0 - 2.1 - 5.1 - 7.1         2.0 Only
5 Version                  2.0 - 2.1 - 5.1 - 7.1           2.0 - 2.1 - 5.1 - 7.1
NOTE:  These updates ‘MUST’ be performed at the Factory.
BSMSPEMBA
Re: SP-3 USB Upgrade Options
« Reply #1 on: 19 May 2017, 08:33 pm »
James,
Thank you for posting this information.
Can you let us know how to check the version of our main board?  If it cannot be done via the menu system, would it be possible to post the version of the board associated with the serial numbers of the SP3?  For example, units 000001 - 000140 are version 2, 000141 - 000210 are version 3, etc.
Thank you
« Reply #2 on: 20 May 2017, 12:42 am »
James,
Thank you
Hi
Yes I am trying to find out an easy way to tell the difference - will report back.
james
« Reply #3 on: 20 May 2017, 02:38 pm »
Date: May 19, 2017 at 4:28:01 PM EDT
To: James Tanner <[email protected]
Subject: RE: SP-3 USB Upgrade
Opening the enclosure and looking at the left front corner of the large bottom board.
 Almost all SP3's shipped after 2012 have revision 4.0.
SP3 Main boards:
R2.0  08/2011
R3.0  03/2013 (EMC approvals)
R4.0  06/2013
R5.0  11/2016 (supports new USBX and DSD, shipped in SDP-45)
WillyP
« Reply #5 on: 22 May 2017, 12:41 pm »
Hi James,
Thanks for the info. I assume that a new SP-3 will have the USB Upgrade. If this is right, when can we expect the new SP-3 in the Netherlands? How much (approximately) will the price rise of the SP-3?
Willy
« Reply #6 on: 22 May 2017, 03:01 pm »
Hi James,
Willy
Hi Willy
Yes any new SP-3's  will have the new boards and are currently being produced.  There is no change in prices yet.
james
WillyP
« Reply #7 on: 22 May 2017, 05:37 pm »
Thanks James,
That is good news. Let's hope that the cubed version of the 9BSST-2 power amplifier will be finished real soon now.
Kind regards,
Willy
gbaby
« Reply #8 on: 23 May 2017, 05:40 pm »
James, I guess if one owns the BDA3, the USB upgrade would be redundant, correct?
« Reply #9 on: 23 May 2017, 06:09 pm »
Correct.
james
ragg987
« Reply #10 on: 27 May 2017, 10:54 am »
Hi James, considering this for my 2012 unit (presumably board R2.0). What advantage does a R5.0 board offer from a video pass-through perspective? Does it support 4k and HDR? If not yet I may hold off if these are in the pipeline.
From the SP3 support page, it mentions HSR82.2 (HSR82P) as being the latest (2015) board - is that the same as R5.0?
Also, it seems you are forking the firmware for 2017 units - if I get the R5.0 board does that take me to the new fork of firmware?
« Reply #11 on: 27 May 2017, 11:42 am »
Hi
I will ask for Mikes input but the main circuit board is not involved in 4K - that's the new HDMI board which has been used now for a while.
james
ragg987
« Reply #12 on: 28 May 2017, 09:55 am »
OK thanks, seems I am confused about the boards! Would appreciate your input on upgrade of video chain.
WillyP
« Reply #13 on: 6 Jun 2017, 10:55 am »
Hi James,
Will the new SP-3 have the new look of the BCD-3 and the Cubed amplifiers or will it have the look of the "older" SP-3?
Willy
« Reply #14 on: 6 Jun 2017, 11:22 am »
Hi James,
Willy
Hi Willy
The cosmetics are not changing.
James
gbaby
« Reply #15 on: 6 Jun 2017, 09:28 pm »
Assuming one has a unit that the USB port can be upgraded for DSD surround. How can the SP3 play surround DSD without converting to PCM? How does it handle the crossover frequency?
WillyP
« Reply #16 on: 31 Aug 2017, 11:57 am »
Hi James,
Can you tell me which version main circuit board a SP3 of five years old will have?
Kind regards,
Willy
May, 2017
Hi Folks,
WillyP
« Reply #17 on: 31 Aug 2017, 12:27 pm »
Oops, something went wrong.
Hi James,
Can you tell me which version main board a SP3 has of 5 years old?
Are there any differences in sound quality or do all the versions sound the same?
Kind regards,
Willy
« Reply #18 on: 31 Aug 2017, 03:08 pm »
Hi Willy - no differences.
james
WillyP
« Reply #19 on: 31 Aug 2017, 03:10 pm »
Thanks James,
And which version main board will a SP3 have of five years old?
Willy
