SP-3 USB Upgrade Options
0 Members and 1 Guest are viewing this topic. Read 5946 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP-3 USB Upgrade Options
« Reply #20 on: 31 Aug 2017, 05:01 pm »
Thanks James,
And which version main board will a SP3 have of five years old?
Willy
Not sure - you have the MB version 2 - I will have to ask engineering.
james
ragg987
« Reply #21 on: 31 Jul 2018, 03:41 pm »
Hi James, I am UK-based and trying to get my SP3 upgraded to one of these 2 options (am inclined to option 1 as I have no current use for DSD):
1.   SP-3 with version 2 - 3 - 4 or 5 main circuit board can upgrade to STEREO plus SURROUND MODES PCM 192/24 ONLY for $600
2.   SP-3 with version 2 - 3 or 4 main board can upgrade to STEREO plus SURROUND MODES PCM 192/24 as well as STEREO DSD for $1000
NOTE:  These updates ‘MUST’ be performed at the Factory.
Speaking to the UK Bryston distributor, I am getting inconsistent info compared to your posting and they tell me that I can get the USB upgraded to stereo PCM but not multi-channel for option 1. My SP3 is from late 2012 (I suspect board version 2). Can you tell me if the PCM multi-channel upgrade option is still available?
If available, can the UK distributer do this themselves or must it return to Canada? They tell me they can do the PCM stereo-only upgrade here in the UK.
