USB Cable Digital Players
0 Members and 1 Guest are viewing this topic. Read 952 times.
XKevinX
« on: 13 May 2017, 11:35 pm »
I'm sure this has been covered, but does the quality of the connecting cord from my external HDD to my BDP1 make any difference?  Currently using the flimsy cord that came with the HDD.
Thanks.
CanadianMaestro
Re: USB Cable Digital Players
« Reply #1 on: 14 May 2017, 12:34 am »
It shouldn't be critical, unless it is poorly constructed. No need to spend $$$ for the USB cable from drive.
The digital cable the connects BDP to your DAC is more important.
reelvox
« Reply #2 on: 14 May 2017, 01:05 am »
+1
XKevinX
« Reply #3 on: 14 May 2017, 01:06 am »
Thanks, yes I'm using a high quality AES cable between the BDP1 and BDA1
