0 Members and 1 Guest are viewing this topic. Read 9937 times.
Audio OutputsThere is a pair of stereo balanced outputs via Neutrik XLR style connectors and one pair of stereo unbalanced outputs via gold plated RCA phono style connectors. Each of these will drive down to a 50ohm load. This means that Dave will work with all known pre-amplifiers and is able to drive very long audio cables without difficulty. Both audio outputs work at the same time so this allows Dave to be connected to two pre-amplifiers if needed.As Dave features a digital volume control it can also be connected directly to a power amplifier without the need for a preamplifier.
Nice review, Jay! Most compression drivers are going to need a correction network to even out impedance and FR + higher order xo's but they can still work well with small SET amps. I think impedance and phase curves are most telling wrt compatibility and I think that's mostly what we hear, the output impedance of the tube amp certainly doesn't play well with many speakers. So with the Dave I think if we consider current capabilities, i.e. is it rated to drive 8 ohm? The user manual says no:http://www.chordelectronics.co.uk/wp-content/uploads/2016/09/Dave-User-Manual.pdfWebsite page: http://www.chordelectronics.co.uk/product/dave/I was actually thinking about this as Jay has some of my cables and an adapter to go from Dave to binding posts, and was getting some results that remind me of break-in but could also be impedance mismatch which may be the case. As my cables are very clear/neutral it will be more obvious vs most other cables. It is likely the output section of the Dave is running out of current and causing current clipping but unless we know how many amps it's capable of putting out we can only guess. I also made cables for Roy, he wanted RCA jacks on the speaker but I am glad he ended up going with binding posts as now it will be easy for Roy and Jay to try other amplifiers and use the Dave as a preamp. For many, even a great majority of Omega users, the best capabilities of the Omegas are only realized using a decent SET amp. Not that other amps aren't ok, but it's much more hit or miss I think. The Dave could work with an autoformer to achieve the current required to drive 8 ohms, but then you'd probably be voltage/SPL limited.
syzygy,Those are Super 3 Desktops, not Super 3T's, and they do need a sub as they are quite a bit smaller than the Super 3i or Super 3T.
This strikes me an an ideal use for the First Watt F4. This is a unity gain amplifier that turns a voltage input to a current output.
Actually, the labels on the back of the speakers state that they are "Super 3T Desktop".
With an F4 you'd still be limited to 6.7V...On it's own, if the Dave outputs .5A it's limited to 4V max before current is limited. I'd also guess the output impedance will make for a damping factor low enough to be an issue as well. At low volumes it might be fine though, but folks using the Dave direct should understand it's limitations and that they might not be getting the best possible results, especially as volume is increased.
Or they could be getting far better SQ by not introducing additional components such as amp (which is the DAVE designers argument and suggestion, which he enjoys with horns). Doesn't hurt to experiment and of course room size/conditions can make for different needs. Dave, are you saying that the extremely low output impedance of the DAVE could be a bad thing for sound quality in direct combination with the Omega speakers? Would appreciate a further explanation as to why you think this could be a problem, thank you?
It depends on what you consider low... preamps generally have much higher output impedances vs amps. A typical preamp, even one with low output impedance for a pre, is still too high for an 8 ohm speaker. What I said was the damping factor is likely to be too low which means the output impedance is too high. But I didn't see specs for output impedance for the Dave in the manual. Unless it's abnormally low for a preamp then it's probably very high relative to an amp and the result will be a very low damping factor. I assume this based on the fact they say it will drive down to a 50 ohm load and not an 8 ohm load. Current Omega drivers will work out well driven by a large range of amps so there would be no problem with a low output impedance amplifier. That wasn't really the case with the older 4.5 hemp driver, it didn't like low output impedance amps. No matter which way you slice it the Dave isn't going to have much headroom so higher SPL operation will surely be compromised. But not everyone cares about higher SPLs especially for a desk system. I just don't want people to think this is a reasonable solution in every circumstance. Personally, there's no way I could live with 2W peaks. I also think a good SET amp will likely be far better vs the Dave by its self in the same way a really good tube preamp or buffer is often better vs a passive preamp but personal preference comes into play too.
