0 Members and 1 Guest are viewing this topic. Read 78856 times.
The 147th AES show was focused on IMMERSIVE audio just concluded October 19th 2019 and the MAIN theme was immersive audio is ALL that was going on. Right now Dolby Atmos and Sony's new 360D and the feeling at the show was that stereo is DEAD and everything is being remixed and the studios are focusing on IMMERSIVE audio. This is not surround if you are confused. Immersive audio can be experienced in your room with a traditional 5.1 surround setup and then adding additional height channels high on the wall or in the ceiling.Check out this CEDIA podcast:https://www.cedia.net/insights/cedia-blog-detail/blog/2019/10/25/the-cedia-podcast-episode-147-the-latest-in-audio-engineering
We will be doing an immersive demo at AXPONA in April. Can you suggest some tracks to play? Thanks.
Hi Tommy, I think Riders on the Storm sounds great in immersive as that thunder in the beginning of the song comes from above you. Any kind of electronic dance music will literally sound exactly like you are standing in the middle of a night club or a rave. Big band music like Sing Sing Sing will have your hair blowing back like the guy in the Maxell Tape ad. I think demoing something recorded in a live setting is very important in an immersive mix as you feel like the audience is all around you. Queen Live at Wembley always knocks my sox off. I subscribe to Qello.com which has hundreds of concert videos if you are also using a PJ in the demo. Turn down the lights, fire up Freddy on the big screen and add your immersive upmixer and you are there.You should absolutely get the new Atmos mix of Abbey Road as this is where the puck seems to be headed as more and more recordings will be released remixed for atmos or Sony 360.As for your speaker placement I would use 5.1 bed channels and add 2 front height channels above the L-R speakers and then 2 rear height channels. Atmos places rear height channels at the back of the room in line with the front L-R channels. Auro 3D, and DTS place the rear height channels above the surrounds. I would recommend using book shelves for surrounds. To get started anyone who has a 7.1 system can take the rear 2 speakers and place them above the front L-R channels and now you have a 5.1.2 immersive system. I would avoid replicating ceiling speakers as I think they are a barrier to entry for most people thinking about an immersive setup. Bookshelve speakers work great as height channels mounted high on the wall.I think you have a competitive advantage in that your amps run cool and are rack friendly.For a demo I would also think about starting a familiar track in two channel and after you get that first smile hit the remote and switch right into the immerive upmixer and watch the smiles turned into jaws dropping. Please post your thoughts.I am very interested in your take on this and read the reviews from your last demo with the 5 channel cherries.https://youtu.be/X8uPIquE5Oo
I listened to Kenny Wayne Shepherd's new album (Traveler) on Qobuz so I decided to pick it up and seen it was available on Blu-ray so I got it. I'm very happy with the atmos mix because it sounds like a good 2ch mix with air and space in my room. TV screen pic.
just ordered Kraftwek 3D in atmos/blue ray.http://kraftwerk.com/catalogue/index-BLUray.html
I've had it for awhile, very good mix.
