Open Baffle Resources: Plans and Kits (no longer relevant)
0 Members and 1 Guest are viewing this topic. Read 14386 times.
JohnR
(As suggested in the thread, the content here has been consolidated into the DIY Drivers thread:
https://www.audiocircle.com/index.php?topic=149613.0
« Last Edit: 17 Apr 2020, 07:50 pm by JohnR »
poseidonsvoice
    • 2 channel/7 channel setup
Re: Open Baffle Resources: Kits
« Reply #1 on: 5 Apr 2017, 02:18 pm »
Music & Design NaO dipole Kits: http://www.musicanddesign.com/products.html
Best,
Anand.
JohnR
Re: Open Baffle Resources: Plans and Kits
« Reply #2 on: 5 Apr 2017, 02:28 pm »
Thanks  :thumb:
TomS
JohnR
« Reply #4 on: 5 Apr 2017, 02:37 pm »
Oh, I thought they were complete speakers... which ones are kits?
« Reply #5 on: 5 Apr 2017, 02:50 pm »
You can also purchase the 10" and 15" OB woofers separately and build your own OB speaker using the FR or horn driver of your choice. They also sell an extensible crossover unit that allows for use of FR or horn drivers. You can also purchase the frame, but you could build one for significantly less.
randytsuch
« Reply #6 on: 5 Apr 2017, 04:33 pm »
Is the betsy considered a kit?
http://wildburroaudio.com/speakers.php
Or you can  move this to drivers if that is more appropriate.
I was also going to add Hawthorne Audio but I guess they closed, although someone may be taking over for them.
Randy
OzarkTom
« Reply #7 on: 5 Apr 2017, 05:15 pm »
 http://www.commonsenseaudio.com/
  Suitable for bass reflex, bass horn, open baffle, and transmission line cabinets
drewm
« Reply #8 on: 6 Apr 2017, 07:40 am »
GR-Research has quite a few other high end open baffle speakers that don't appear on their website:
NX-Treme
http://www.audiocircle.com/index.php?topic=145270.0
NX-Otica
http://www.audiocircle.com/index.php?topic=141654.0
NX-Otica MTM
http://www.audiocircle.com/index.php?topic=144907.0
All 3 of those pair fantastically with the GR-Research open baffle H-frame subwoofer:
http://www.audiocircle.com/index.php?topic=125556.0
JohnR
« Reply #9 on: 6 Apr 2017, 01:54 pm »
Thanks Drew - just not sure which of those are currently available?
The woofers are on the Drivers thread. I might end up merging the two threads as people seem to see drivers and kits as the same thing - ?
JohnR
« Reply #10 on: 6 Apr 2017, 01:59 pm »
Thanks Randy, added the driver to the driver page and the project to the designs page. (I think I need to simplify).
Unfortunately can't list Hawthorne as not currently available (too much work already!)
 :thumb:
JohnR
« Reply #11 on: 6 Apr 2017, 02:07 pm »
Thanks Tom, added to Drivers thread  :thumb:
drewm
« Reply #13 on: 9 Apr 2017, 07:40 pm »
All of them are currently available, GR-Research isn't very good about keeping their website up to date
mlundy57
« Reply #14 on: 13 Jun 2017, 04:14 pm »
GR-Research also has kits and plans available for the X-Static main speakers and X-Voce center channel. Don't let the inexpensive price of these speakers fool you into thinking they must not be very good. They are and at their price are one of the best bargins out there.
Mike
