0 Members and 1 Guest are viewing this topic. Read 20533 times.
A SET (like the Zen) with no negative feedback will have a very low damping factor. In the case of Omega speakers where the drivers are very light and need very little damping, a SET with it's low damping factor can produce a very nice bottom end without the need of a sub. An amp with a high damping factor can lessen the bass output, but not to the point where the speakers will sound lean. In listening to a variety of Omega speakers on anything from SETs to SS and almost everywhere in between, this has been my experience.
Oliver's work has always seemed great to me. I live 4 blocks from him. I really only use vintage power iron. Output iron that has aged gets me.
RE: damping factor. So, I've ordered the CAMs and my "amp" has a damping factor of 55 milli ohms (0.055 ohms) , and assuming I have low impedance cables, what should I expect out of the CAM?
Something to note is that I've found my CAMs to need much less boundary reinforcement than the 3xrs. The CAMs have more midbass and bass, which is of course due mostly to the larger driver. This is just my personal experience. I've read where others were satisfied with the midbass / bass of the 3xrs when used with amps like the Decware Zen. I'm a Pass Labs / First Watt owner, though I'm keen to try the Decware some day. Point is, there are many things to consider with amp / speaker pairing. Overall, I think the CAMs are probably the most versatile stand-alone speaker Omega offers, based on size, midbass/bass production, ease of placement, simplicity, and tonal balance. Note I haven't heard the dual RS5 based speakers, but their lower impedance could MAYBE present a little bit of trouble for amps like the Decware. It depends. So, this is something that adds to my assessment that the CAMs are probably the most versatile overall. Again, Louis is the man. He won't steer you wrong and enjoys talking to his customers.
I had an extensive discussion with Louis on the issue of impedance before buying the Omega HO 3-1.5 speakers, which are rated around 6 ohms. My JWN 6V6 amp only has taps for 8. Louis said it would not be a problem. I agree. Not really a problem at all.
You'll get 20khz, but it may be down a few dB. That is not necessarily a bad thing. Normal adult hearing rarely exceeds 16khz, nor is there a great deal of musical information up that high. Additionally, the Fletcher-Munson effect means that rolled off highs and lows actually give a greater impression of soundstage depth. If you actually need that top half octave you can alway add on a supertweeter, possibly placed off axis for greater dispersion.
You may be asking too much from the CAM's if you want Metal to Classical at satisfying levels in a larger space. Near field with some boundary reinforcement may be a different story. There are also the SAM's, which I own. They are significantly bigger than the CAM's and have the potential for better bass performance. Alternatively, you may find your musical tastes better served by the Super 3 HO Monitor, which has the same driver surface area of the CAM but IMO a better top end.
I highly doubt you made a bad choice. Like anything else in life, there's really no way to know what your preferences are without giving different things a try. Unfortunately, this hobby can be expensive and difficult to try a lot of different things in order to dial-in the "nuances" of your preferences. Maybe you like chocolate. Is there a certain brand? What type of chocolate? Dark? How dark? From what country or region? And so it goes. Know what I mean? I've been in this hobby for around 20 years, maybe longer. I've tried LOTS of gear. CAMs are in my music system and will remain there for the foreseeable future. However, I'm very fond of the RS5 based speakers and will probably buy a pair of HO 3's at some point too. It boils down to those nuances, which can entirely depend on your mood (or type of music you want to listen to and how you want it presented to you at any given moment). Just because 70% dark chocolate from Sweden is your favorite, doesn't mean that you don't find 60% dark chocolate from Mexico also good or maybe even preferable on occasion. I think you'll be happy with the CAMs especially nearfield. They're very flexible, refined, resolving, and really don't misstep.
Nice. Yeah, I don't need a whole lot of volume either. I mean, sometimes you certainly want to jam, but feeling the music doesn't always equate to loudness. But what is "loud?" 95db at 6ft might be too damn loud, anyway, even at the most jammin' of times. But yeah, anyway, I'm dealing in the realm of hypotheticals at the moment. Yay for the sub. I'm Impatient. Monday will be a month since ordering.
I am consistently surprised at how much louder many other people listen. I had a guy over to the house this weekend. He had it up around 95dB for a while. And then started to try to yell over it. I am usually in the 75-80dB range and sometimes way less. Even in my isolated and soundproofed listening room.
I agree completely. It's insane to me how loud some folks like to listen.
