0 Members and 1 Guest are viewing this topic. Read 20179 times.
Agree with all your comments, roscoe. All things considered, the electrical behavior is just one element of the whole. With dual drivers, the impedance may be lower than a single driver, but the difference is likely (for the most part) negated by the increased sensitivity of the system (as you've alluded). Keep in perspective too that we're talking about SUPER light drivers, with strong motors. They will respond to fractions of a watt. Which brings me to another point...I listen nearfield, both out of necessity (relatively small space) and also to avoid room reflections from dominating the presentation. My ears are 8 feet (usually more like 6.5 - 7 feet) from the drivers. I need VERY little power to get the CAMs singing at my listening chair. Most of the time I don't enjoy listening loud anyway. I prefer comfortable volumes (likely 75db - 85db)....similar to Srajan at 6 Moons (who is also a Pass Labs / First Watt fan). So, an aspect that is SUPER important to me is system quietness. I sit close enough to the drivers that hiss / hum can be bothersome. This can be tricky because Omegas let everything through, for better (music signal) or worse (system noise). It isn't so much a problem as much as it is something worth noting as another variable.
thanks to everyone for responding and chiming in. interestingly enough, a few weeks ago i took steps to build the second system i've always wanted to try by ordering a decware se34I.5 amp . i'm now deciding on the right omega speaker. they're made not too far from where i live and i am willing to travel up there, but unfortunately from what i've heard there's really no way to hear anything first. i took the plunge on the decware w/out hearing it so i guess i'll be doing the same w/the omegas.
thanks, I think I'm leaning toward the CAMs. Love that Fi amp and I wanted one. I contacted Garber about getting one a while back, but didn't get very far. It is a beautiful piece.
If you wanted one that is similar (same circuit, different look, maybe different parts), Oliver Sayes would probably build you one. He's on USAudiomart as SonicOli.
I had one of Oliver's 2A3 amps. It sounded wonderful, but was very unreliable.
