0 Members and 1 Guest are viewing this topic. Read 9779 times.
I do suspect that and hope someone has a more definitive answer / solution
If you don't like my answer, then tuff hop.
We had a similar thing happen with our cable... we'd get high upload latency and packet loss when it rained.Turned out that the contractor who replaced the coax on our block didn't use the right grade of cable... the weight of the water plus wind would stretch the cable and open a crack in the housing.
"We can't send email farther than 500 miles from here," he repeated. "Alittle bit more, actually. Call it 520 miles. But no farther."
You could try putting shorting plugs in the input jacks which will ground the inputs of the amplifier. When the inputs are grounded and the amplifier is turned on any hum or noise you hear is only being produced by the amplifier alone. If it makes the same noises when you shut it down and has a hum when turned on I suspect it might be one of your main storage caps in the power supply going bad. When one of your power supply rails has a different voltage than the other funny things can happen to the amplfier. This can happen if one of the main storage caps is failing. When you turn off the amplifier the storage caps keep suppling power to the circuitry in the amp until all of power stored in them is used up. If one of storage caps is failing it will have a lot less energy stored in it and will be exhausted first which can result in a voltage imbalance on the differential input. This can cause the funny noises you hear when the amp is powering down. The noises are probably the amp oscillating because of what is happening at the front end. Of course this is only a hypothesis and something else may actually be going on.Good with your trouble shooting.Scotty
The first thing I do when I hear hum is wiggle cables. Broken cables can do this, or having hot/ground mixed on something that is DIY. Maybe it's just coincidence, with the rain?
