0 Members and 1 Guest are viewing this topic. Read 9788 times.
I checked the dedicated lines and I am getting 119 V on one line and 120V on anotherCould this be a clue?Previously, it was 119V on both.This was checked from hot to neutral and from hot to ground to see if there was a difference. There was not. Shouldn't this mean the grounding is OK?However, I went outside and found the ground rod. It's a piece of rusty rebar very corroded. Unknown length. The copper wire is still good though.The old telephone system is grounded about 40 feet away around the back of the house to a piece of galvanized pipe that runs into part of the concrete poured patio area.The telephone system is Not used but I cleaned up that ground and there was no change.I purchased two new copper plated 8 ft ground rods and will install those sometime this week.I still am very concerned about the Loud buzz noise that the speakers make when the amps turn off. It's the same in both channels. It's quite loud- kind of like a large bumble bee / large winged grasshopper but metallic, slower in cadence and has static noise. It rises, falls and diminishes in about 2 seconds. These have NEVER made this noise before. I unplugged all devices from the 2nd dedicated outlet and the noise is still there.
"I floated the ground on one of the amps and the higher frequency hum went away in THAT channel"Ah.. a clue..
I would assume this is the same as having all devices operate off the same circuit.
No, I said ALL components running off ONE circuit. IMO, it's likely a potential difference in the grounds between your amps and preamps, which are powered by different circuits and have grounds that are connected via IC cables AND power cables so there can be SCIN and/or ground loops. For most systems running multiple lines only causes problems, but I'm tired of repeating myself... The fact lifting ground on one amp eliminated the problem point to the possibility that I've been right about your issue all along... you might want to re-read my previous posts.
the extra noise when the amp capacitors are discharging is another clueCould that be some sort of feedback?Not sure what this indicates though...
extra noise/hum when caps discharge indicates the caps need replacing - or in the case of a mod there need to be more capacitance...cheers
Another consideration. Dimmer switches. See if they all are completely off in the house. Does the noise stop or change intensity. Yes, they can cause issues in your alternating current even when said dimmers are not on your dedicated lines. Plus the second component is radio frequency emission and your particular RCA cables. Dimmers also emit RF and create these symptoms. I find led compatible dimmers particularly noisy.
I have been re-reading the posts. Will pursue leads (no pun intended)However, I am stumped as to why this cropped up when no changes were made to any of my electrical systems / connections equipment etc. This new hum just appeared and frustratingly since I had just resolved a hum and the system had been dead quiet until these recent hard rains.
Not sure about other areas but I know where I live, more than one ground rod is not recommended.
All grounding electrodes as described in 250.52(A)(1) through (A)(7) that are present at each building or structure served shall be bonded together to form the grounding electrode system. Where none of these grounding electrodes exist, one or more of the grounding electrodes specified in 250.52(A)(4) through (A)(8 shall be installed and used.
