0 Members and 1 Guest are viewing this topic. Read 9417 times.
Vinyl "deforms" when it is played, and it takes several hours for it to "rebound" back to its original shape.
Quote from: John CaslerVinyl "deforms" when it is played, and it takes several hours for it to "rebound" back to its original shape.If you believe that you should also know that the heat generated by the friction of the stylus makes the deformation irreversible. For the very best sound from vinyl, new LP should be played only once.
Your vinyl groove deformation theory is a load of crapola. 1) The stylus contacts the wall of the groove at least half way where there is plenty of mass to withstand the transient side force. 2) The force vector is directed downwards at about 45 degrees towards the meat of the platter. 3) Any distortion on the inner wall of the groove will be counteracted by the distortion on the outer wall of the adjacent groove during the next revolution of the disk. The point is, why pollute the minds of vinyl newbies with old wives tales. Their heads are already filled with enough rubbish and ritual regarding CDs. Just let them just spin their LPs and enjoy the music....
Even though the tracking force of the stylus above is only 1.5 grams, this force is applied to such a small area that the pressure on the walls of the groove can be surprisingly high.Measurement of the wear surfaces at higher power using an eyepiece micrometer gives a figure of 20 µm for the average width of the worn areas. Neglecting factors such as the elastic deformation of vinyl, the distribution of forces in a V-shaped groove and the accelerations at the stylus tip during tracking, simple calculation based on these figures gives a stylus pressure of 240 grams per square mm, or 340 pounds per square inch. The transient pressures exerted by a stylus tracing a heavily modulated groove during playback will of course be much greater, but beyond my ability to calculate.
The best defense against groove wear is a clean, unworn stylus and proper tracking force.
I guess I am an old-timer because I remember when the 33-1/3 RPM long-playing record was introduced. I’ve witnessed an ever-growing list of dos, don’ts, and myths grow surrounding LP care and playing. Your 24-hour rule is one of them. Just because a myth is repeated doesn’t make it true.I think we old-timers should start a thread recounting every LP myth and tweak we can remember so the newbies can be fully immersed in the lore. I didn’t make up the one about the heat generated by stylus/groove friction ...
I've accidentally left the tonearm in the leadout groove for hours on end on occasion. Luckily I caught it in time before the entire turntable burst into flames. However, I was not quick enough to salvage the record, which was becoming molten and dripping off the edges of the platter. I quickly doused the needle in my nearby blacksmith's water barrel. The stylus was severely deformed, but a few careful whacks with a hammer and it was good to go again. The vinyl will never play again, but I keep it aro ...
Many of these "variations" are so small that as the stylus hits them they deform. They bend over and the very tops of them may even stretch, like little hairs.
I didn’t see any hair like structures that were likely to be bent, pushed over, worn off, or distorted in any way.
Hey John,I pulled out an old test record and took a look at the grooves of the 15,000Hz band with a stereo microscope. The magnification was only 45x but I could see the ripples and wiggles in the groove pretty well and I didn’t see any hair like structures that were likely to be bent, pushed over, worn off, or distorted in any way. Unfortunately, the ‘scope doesn’t have a camera mount so I couldn’t get a picture. Perhaps you have a photo that clearly shows the hair like structures you are talking about.
Be careful, though: if the record is an odd size, color, or weight or smells different from an average record (we're serious!), you may have an acetate or transcription recording and should proceed with caution. These one-off shellac disks or "lacquers" have a record surface composed of a very soft compound and cannot tolerate even slight abuse or harsh cleaners. In addition, remember that vinyl is an elastic material. Each time you play a record, you deform the groove walls. If you play a record repeatedly within a 24-hour period, the plastic doesn't have an opportunity to "relax" or flow back to its original shape, resulting in permanent damage
