0 Members and 1 Guest are viewing this topic. Read 16178 times.
I'm about to give up on my recently bought Maggies .7 this is a tough decision because I just love how these things sound with 75% of my music collection. The issue is not with the low end per se, acoustic bass sound magnificent. My problem is what the British call PRAT factor, drive and dynamics in the lower frequencies are a turn off when I listen to old Rock music Yes, Genesis et al. I'm seriously considering the Eminent Technology LFT-8b but will appreciate some comments from people with previous experience with this speaker. Can consider a subwoofer if and only if they can completely solve the problem with the low frq's. dynamics, which I doubt. This seems to be an inherent shortcoming of the design. I will like the sub to be my last option, don't like the idea of the extra cost involved, an extra power cord, extra cables, is annoying having an extra box in the floor, and tweeking all over again the speaker's placement.Thanks for your patience and advice
I know this answer might be unpopular - but i think the amp provides the prat factor - not the speakers - If all these posts are telling me that the speaker is the culprit - then for 25 years i have been thinking the issue of prat around amplifiers is all wrong
Back to the original question - the lack of PRAT in a Maggie, particularly in the bass, sounds to me like the speaker is too close to the wall! How far out in the room are they? The attack of Rickenbacker bass (a la Yes and non-bass pedal Genesis) should sound wonderful, so something is definitely up. Although pulling them out further into the room may compromise low bass extension a bit, I'd try that before giving up on them. If that fixes the problem, and WAF is a factor, they can be pushed back when not in use for serious listening...MGbert
