0 Members and 1 Guest are viewing this topic. Read 16161 times.
It's too bad you sold the ET speakers so soon. The hot tweeter issue is easily solved and the tonal balance can be addressed in a couple of different ways.Of course, the midrange driver is the star of the show and these speakers have easily more potential than any of the Magnepan models. But, it takes some work to get 'em there.I'm not sure the Dead Man Walking soundtrack is appropriate evaluation software. I think most of the tracks on that disk are horribly recorded and they will make most speakers sound bad.Cheers,Dave.
Glad you enjoy your ETs. I honestly thought mine sounded better with the tweeter disconnected. You've done way more work on yours then the design warrants, IMO.
Haven't heard the ETs, but the Spatial Audio M3s may provide what you're looking for without venturing too far away from what you like.
Well, I've actually done some work on the speakers, so I think my insight is much better than yours.Dave.
Hi Dave, just curious. How diffcult will be to do the woofer's job in the ET I read somewhere that they're sealed??
I'm about to give up on my recently bought Maggies .7 this is a tough decision because I just love how these things sound with 75% of my music collection. The issue is not with the low end per se, acoustic bass sound magnificent. My problem is what the British call PRAT factor, drive and dynamics in the lower frequencies are a turn off when I listen to old Rock music Yes, Genesis et al.Can consider a subwoofer if and only if they can completely solve the problem with the low frq's. dynamics, which I doubt.
Hi Early B, I using an Acoustat TNT-200 recently worked by Roy Esposito and a Vacuum Tube Audio SP9 preamp with a digital front end, my analogue gear is currently out of action. My previous speaker were Merlins TSM which provided way more articulated and tight bass. Now, I hear my music at reasonable levels ( not head bangers here). The room dimensions are 16'.5 x 19' my main issue is, that the "tapping the foot" factor in the music's foundation is not there, the "low end" (I guessing between 40-80hz) rhythm and pace feels sluggish compared with the Merlin. Don't get me wrong they are fabulous, maybe to good in other areas for their own good. Probably I been to harsh toward these $1400.00 speakers
Really?As an owner of the speakers, I think my opinion is just as valid as yours. You point out many technical flaws with the speaker. You've taken the time to fix these problems to your satisfaction. I applaud your effort there. I chose to put my Meadowlark Kestel Hot Rods back in service, listen to Johnny Cash the way he should sound, and sell the ETs. The question for me, and I'd say to the OP as well, why not simply purchase speakers that aren't as flawed? A very easy solution.I seriously doubt the LFT-8 is a better speaker than the Vandersteen 2CE (any iteration), no matter the amount of tweaking. That's MY opinion as one who has owned both models. Others may disagree.
If you think the Vandersteen 2ce (or even a primitive design like the Meadowlark HotRod) is preferable to LFT-8's then we clearly have a different reference regarding speaker system performance. I wouldn't even consider the Model 5's equivalent.Vandersteen speakers are extremely over-priced...for what they are. And anybody can throw some quality Scan-Speak drivers in a box and make them sound decent.My insight regarding the ET speakers is related to their 'potential' and not necessarily their stock performance. I have listened to my pair for well over a year now....in stock form and with various modifications. I think I have a pretty good idea the type of potential these speakers have. But, if you think your insight is equivalent to that then so be it.Cheers,Dave.
Hi Hiphile: Your TNT-200 looks almost new. Did you buy it used or new? Roy did a great job on your unit. Wanted to have it done by him but just couldn't afford to send it to him to have the work done as the Canadian to US exchange rate is low. Can you take closer pictures of the innards especially the PCB boards? I'm curious as to which parts were swapped/replaced. Can tell that the smaller caps have been replaced. Really enjoying mine (bought used and had a local tech, who is very good and has done repairs/replacement/mods to Cello, Mark Levinson, Krells, Macs, and other high-end SS and tube gear, go over it) aside from the slight turn on thump (I've read that it's normal for these amps). The pre is a TNP also gone over by the same tech. (The cost of the repairs/replacement parts, small mods, and labor for both units ran $1k which would not be far from Roy's works aside from the shipping and exchange rates.) It mates well with the Acoustat 3s in a small 11'x10.5' treated room. Also have a HSU VTF-2 sub handling the lower end of things. Your pre is probably quite a bit better than the TNP... so the electronics you currently have would mate well with a selection of loudspeakers if you choose to go that route. I agree with most of the other posters that adding one sub (or two if it'll fit in your room) is probably the best route to take as the dealer isn't giving you much of a trade in value (which is kind of strange since you purchase the .7s from them ). Hope you find the prat/sound you are looking for. Sincerely,Kingsley.
