Recommendations for a small sub?
0 Members and 1 Guest are viewing this topic. Read 4751 times.
LesterSleepsIn
  • Occasionally consternated
« on: 16 Nov 2016, 04:15 pm »
I need a good, physically small sub for an office area. The office itself is 12 x 12 but the actual space for the sub is small. Any recommendations? The smaller the better ... maybe.
Best,
Lester
sunnydaze
Re: Recommendations for a small sub?
« Reply #1 on: 16 Nov 2016, 04:41 pm »
I don't know what you consider large, but look into Gallo CLS 10.   Unsure about availability -- they were being closed out over the summer for about $500.  Fast musical sub that keeps up nicely with my quick Omega Super 7 XRS mk2 speakers.  Nicely adjustable, doesn't overload my 10 x 11 room.
http://www.roundsound.com/classico-cl-s-10-subwoofer.html
EDIT:   a nice feature of this sub is that high-level hookup (ie. amp connection with speaker cables) allows high-passing (fixed at 100 hz) to you mains if you choose to, relieving them of low bass duty.  Better purity, naturalness and ease.  Of course, you can also run mains full range.
« Last Edit: 29 Nov 2016, 06:47 pm by sunnydaze »
johzel
« Reply #2 on: 16 Nov 2016, 04:52 pm »
Here's one I'm considering for a similar area:  Sumiko Sub Zero  Dimensions (WxHxD)
9.65x10.8x11 in.
http://www.sumikosubwoofers.com/en-us/products/s-0
GreatDane
« Reply #3 on: 16 Nov 2016, 05:44 pm »
I really like my Totem Kin mini subs. I run one in each corner in my music room.
https://totemacoustic.com/en/kin-mini-sub
sunnydaze
« Reply #4 on: 16 Nov 2016, 05:50 pm »
Nice looking sub!     :thumb:
max190
« Reply #5 on: 16 Nov 2016, 06:45 pm »
REL T-Zero
Connect it using the high-level neutrik speakon connector
https://www.youtube.com/watch?v=DUk-EEdum9I
bflex
« Reply #6 on: 16 Nov 2016, 09:15 pm »
REL t zero for sure. I have one with my harbeth c7es3 and love it.
« Reply #7 on: 16 Nov 2016, 10:34 pm »
Been on a similar quest, but want a "real" subwoofer (in-room F3 = 20 Hz).  Cheapest/smallest I could find was SVS SB-1000 ($499, 13.5" x 13" x 14", F3 = 24Hz) and Rythmik L12 ($539, 14" x 14" x 15.5", F3 = 18 Hz).  Either should be good quality pieces, especially the Rythmik.
Note they would hook up to speakers with F3 = 42 Hz, so why bother with a "sub" that is only rated down to 35 Hz?
I.Greyhound Fan
« Reply #8 on: 16 Nov 2016, 10:42 pm »
I use dual 10" Martin Logan Original Dynamo's with my Magnepan 1.6's.  The newer Dynamo 700 is comparable.  It is small in size and packs a punch.  Very musical tight and controlled bass.  It is non ported.  They can be found on ebay for good prices.  There is an original dynamo on ebay for $185. 700's are going for about $300-400 used.  They sold for $650 years ago.  They supposedly go down to 24hz but 27 is more realistic.   They are about 11x12".
« Reply #9 on: 17 Nov 2016, 01:25 am »
A smaller but more expensive options are the amazing TBI subs such as the Magellan VI su ($800, 14.5" x 14.5" x 7", F3 = 20 Hz, but are passive so a power amp is required).
Bob Stark
« Reply #10 on: 17 Nov 2016, 01:56 am »
Check out James subs with either the 10" or 12" woofer.   Excellent sound in a compact enclosure.  Read up on the reviews and see for yourself.
« Reply #11 on: 17 Nov 2016, 11:41 am »
Unfortunately not cheap or well known.
LesterSleepsIn
« Reply #12 on: 17 Nov 2016, 01:53 pm »
Thank you all, great suggestions. Right now I'm leaning towards the REL T Zero as a starting place but the others are certainly attractve and within the realm of possibilities. Bflex, I too will be matching the sub to the Harbeth C7ES3s.
Lester
