0 Members and 1 Guest are viewing this topic. Read 28069 times.
Yeah I have two flirc cases though I did paint mine.
I gave in and ordered the HiFiBerry DAC+ Pro. I can have this hooked up to the pi2 and use the usb dac on the Pi B+ as a comparison both running latest moodeaudio.
$90 for streamer/player/DAC is highly intriguing, but have zero DIY skills for this kind of stuff. (For me, running a computer to the DAC equipped with a remote control is a stretch into high tech.) Is this gear really, really, really operationally stable? I dipped my toe into a modded Squeeze Box 2 years ago (fantastic design concept), that wasn't stable, and backed out for years. Is anyone in the business of building them for sale? Say in a decent box?
Might be a bit until I get to it.What touch screen you using in your setup?
If anybody has any input on which channels for both 2.4 and 5GHz work best, I'd appreciate it.
I got on this train over the holidays.I bought the Cana-kit pi3 from Amazon. Not a bad price for the pi, 5v wall wart, and a case at $50 shipped Prime.I have been using it with my Schiit Modi and Moode Audio. It was easy to set up, though I find that the Moode set up guide left out some basic things (e.g., how to connect with the pi initially-- it actually broadcasts its own wireless network connection; only after you set it up to join your home wireless can you reach it via its IP address!).I can put together a quick how-to if folks are interested.I think it sounds quite good overall. I have read that some folks are using the pi plus a Hifi digi hat out to Schiit's multibit Modi 2 (the SPDIF in has slightly better performance than the USB) and are quite happy. I went the route of the Mamboberry LS, it just arrived. I may try the Kali reclocker with it later. Looking forward to comparing it the Modi!It has been very stable, and my fairly large FLAC collection on NAS loads quickly. So far I'm pretty stoked .
@Odal3, I ordered a Kali with the Piano DAC. Thanks for the reminder
