0 Members and 1 Guest are viewing this topic. Read 5898 times.
I am using the Herbies Way Excellent II mat on top of the stock plastic upper surface of my Trans Rotor Rondino turntable, and that made a noticeable improvement. Now I'm wondering about clamps. Several VPI owners I know recommend against using any clamp at all with the VPIs. OTOH, there are some after-market offerings of clamps in the thousands of dollars.In the October Stereophile, Robert Deutsch - - who uses the Herbie's mat also - - recommends a TT weight (not a clamp) from Harmonic Resolution Systems at a hefty $440 (for the heavier one). (He also recommends the PHT "micro transducer.")Any experience out there with either one of these gadgets?
PS I'm still looking for an HRS used, but even at half price it's spendy!
This is a serious offer. When you find one, weigh it, and I"ll make a diy one of the same mass and send it to you for comparison.
Scott,I'll definitely take you up on that. In fact I took a fit and did some looking and found this on Ebay:Aluminati SS record wieghtIt is 1250gThe HRS is 900g
I have used weights, clamps and nothing. I got several weights of different shape and mass. Their efficacy vary from record to record and table to table. Heavy vinyl is less affected by clamps or weights. Platter mats are same way. Results vary on different tables -- especially different on suspended platter vs heavy platter.But one thing that has made a difference across the board is a periphery ring. I would save on a clamp/weight and put it toward getting a ring. I am guessing that the more you keep your vinyl flat and inert from vibration the better. Weight at the center may do that for heavy discs but make it worse with thin ones as you raise the edges, thereby increasing vibration. It's not just inertness though. Sorbo mat can grip a disc but I found some music just lose life on it. Periphery ring gives more details without robbing life out of recordings. Anyway, I use center weight and periphery ring on had mats -- carbon fibre and gunmetal (on different tables). That's where I am.
This has definitely turned into an interesting discussion of accessories. It's nice to hear from those that have experience with their own TT's. I may have to start looking for a ring. I've several lp's that are hard to come by that have moderate to serious warps. I had been thinking about flattening techniques, but a ring may be a better idea. Do rings have any beneficial effects on normal lp's?Can anyone else chime in with knowledge of tonearm wiring?
