0 Members and 1 Guest are viewing this topic. Read 17540 times.
I picked up a matched pair of Russian 6N23P "Rocket" tubes and put them into my Wavestream phono stage. Initial impressions are positive, with the sound at least as good as NOS 6DJ8s from Siemens and Amperex (US JAN). The phono stage seems to have a little more gain as well, but that could be due to the unknown age and life of the tubes they replaced.Does anyone else have experience with these tubes? The matched pair was a bargain compared to NOS tubes I've found other places, and I've got 20 tested/unmatched tubes coming in from Kiev that were a real deal at $7.50 each with free shipping!
I received the second set of matched 2N23P tubes and installed them last night. They are quieter and less microphonic than the tubes they replaced, but I have no history on those tubes, so I'm not sure how old they were. Sound quality is not significantly different at this point. Not sure how many hours it will take the tubes to burn in, but I'll just keep listening as things sound quite good at this point and should just get better.
With soft start the getter would be fully activated and clear all the residues in about 40 hours or less with the usual 4 hours on and rest all the day.
FRM,Thanks. After I posted the above, I noticed some intermittent static, so decided to leave the phono stage on for a few hours today idling while I'm at work. Hopefully things will settle down by the weekend.AC
This amp can stand these hours on?Never let an tube amp alone, if anything go wrong if can made a fire, as Harry Pearson could testify...
I never worry about leaving solely small signal/preamp tubes on unattended. I guess I do this because the current is usually low and the tubes are not likely to run away or red plate at such a low current. That said, i would never do it with an amp or anything with a DHT or rectifier tube.
Years ago I was awakened during the night by a loud humming from my living room. My Conrad Johnson amp, which was turned off, was vibrating wildly until I unplugged it. Then it never did that again.
Would be a cap discharge?
Gustavo,It is a phono stage not an amp, but I was a bit nervous to leave it on. I worked a short day today, though, so it was only on for about 10 hours (yeah, 10 hours IS a short day!). When I got home a couple hours ago everything was fine. I flipped on my amps and cranked up the volume with nothing playing and it was the quietest I've heard the Wavestream--not even any tube rush until the volume knob was past 3:00--no crackling or static at all, and I had to rap on the case pretty hard to get any noise from microphonics (before the new tubes a like fingertip tap would generate a sound through the speakers, so this is definitely better). I put on Cannonball Adderley and the music came alive. I'm not that familiar with the record, but wow, it sounds incredible. Will listen to some of my reference LPs later and report back on what I hear, but so far definitely so good!Evan
The usual recipe to activate the getter is til 4 hours on (2-4 hours, no music) and 20 hours rest in a proper tube heater device (not a amp) for some days, as those used for tube broker.Burn-in tube in a audio amp requires some caution.Would be useful know if the tube vendor alreay made the getter activation in the last 6 months for this tube?
