0 Members and 1 Guest are viewing this topic. Read 17562 times.
The sockets are clean?A tap on the chassis always will made a speaker sound, hence the tubes are electro-mech devices attached to the case.A tap on a hot tube can made a short circuit on that tube, I would not do it.
I've used them also in my Dodd phono pre with results equal or better than most of the 6dj8 alternatives. The 6N1P are pretty similar in most regards.
I picked up a matched pair of Russian 6N23P "Rocket" tubes and put them into my Wavestream phono stage. Initial impressions are positive, with the sound at least as good as NOS 6DJ8s from Siemens and Amperex (US JAN). The phono stage seems to have a little more gain as well, but that could be due to the unknown age and life of the tubes they replaced.Does anyone else have experience with these tubes? The matched pair was a bargain compared to NOS tubes I've found other places, and I've got 20 tested/unmatched tubes coming in from Kiev that were a real deal at $7.50 each with free shipping!
I own both, but have read the 6N1P supposedly sounds better???I can't tell any difference. Both sound as good or better than the Ediswans that I have in my DAC and probably $100 less for the pair?
Honestly, I'm not sure I could tell the difference if I played them back to back. Even in a Dodd amp that came stock with 6N1P, when replaced with the much more expensive 6H30pi the differences were noticeable, but not huge.
Anand,I have had the 6N1P in a Dodd preamp with gain, but switched it out to 6H30dr almost immediately. In that application the more expensive tube provided much more detail. I also have one of the original Dodd battery preamps, the model that uses two tubes. In it, after extensive tube swapping, I've found that a Valvo PCC88 d getter was my best option.
In addition the mu or amplification factor of the 6DJ8 and 6N1P are very similar but the 6H30 is much lower. The 6H30 requires a larger amount of filament current than the other 2. The 6H30 also requires significantly more bias current than the 6N1P or 6DJ8 (and equivalents) to set a good operating point with minimum THD. Best,Anand.
Anand,That's interesting, as I noticed what seemed like more gain when I installed 4 6H30Ps. Of course that could be due to the old 6DJ8s being tired. I'll have to look for the 6N1P--I hadn't heard of them before now.AC
After more than twenty years of tube rolling the 6dj8/6922/6n23p's etc. in various components, I'd say take anyone's opinion about whether certain tube sounds "better" will a massive amount of skepticism. Every component and circuit is different. I've heard the 6n23p sound fabulous in some applications and so dead, lifeless, and dull in another you'd hardly believe it was the same tube.
I think most everyone responding in this thread knows and agrees with everything you said. Every application will sound different. Tubes, power cords, magic rocks, whatever... When someone says they hear something +-, accept that they do, and understand that you may not.
And here is a larger general review of 6922/6DJ8 variants: http://www.head-fi.org/t/761078/6922-tube-review-17-top-6922-6n23p-e88cc-cca-7308-e188cc-tubesBest,Anand.
