Audio/Video Gear and Systems
Enclosures
Letitroll98
Plugging Rear Speaker Port only Half Way ?
0 Members and 1 Guest are viewing this topic. Read 1334 times.
Super Hans
yes with an if, no with a but
23 Aug 2016, 12:01 am »
Hey all, so I've found I like my rear ported bookshelf speakers with only 1\2 the port tube plugged. I folded down a kinda thick piece of material (thin running sock folded in half) so it only fills half the port. I find this sounds better than port fully plugged or totally unplugged. I have to fold the sock down a bit on the inside so it does not vibrate out.
Wondering if you guys can think of a better way to do this. A more acoustically adjustable material or something ? Has to be fold-able so I can fold it down to keep from vibrating out and only plugs 1/2 the diameter of the port. I have seen where people have used tube, some hollow and some solid in the ports, to do this. Any ideas on that method also ?
Thanks guys
jk@home
Re: Plugging Rear Speaker Port only Half Way ?
23 Aug 2016, 12:14 am »
On my KEF LS50s, they supply a full port plug, and then one that is the same material and OD, but with a hole in it.
Maybe you could try some of that black closed cell pipe insulation, with the proper OD and ID, to get the open area you need.
DaveC113
Industry Contributor
ZenWaveAudio.com
Reply #2 on:
23 Aug 2016, 12:27 am »
You can also try stuffing the port with drinking straws or some sort of fibrous material that won't completely block the port.
The changes to the port lowers the tuning frequency of the cabinet so the bass starts rolling off sooner but tapers off more gradually. If you block the port entirely you seal the cabinet and this has more of an effect but it also increases woofer excursion and reduces lf output.
Super Hans
Reply #3 on:
23 Aug 2016, 04:21 pm »
Great.
Thanks for the replies
Enclosures
Letitroll98
