Outlaw 1.5 cut off point.
0 Members and 1 Guest are viewing this topic. Read 1444 times.
Bmotorcycle2003
« on: 7 Aug 2016, 10:42 pm »
Why isn't the lower driver run full range?  Aren't there some phase issues using a filter. I was thinking of bypassing that filter.  Just thinking there just might be an improvement considering different room treatment seen from us all.  Thanks in advance, Bob.
Canada Rob
Re: Outlaw 1.5 cut off point.
« Reply #1 on: 8 Aug 2016, 04:26 pm »
Hi Bmotorcycle2003,
If the lower driver was run full range you would have phase issues as both drivers are now handling the higher frequencies which are more directional - you lose that single point source.  With the lower driver rolled off at 500Hz the sound waves coming from that driver are no longer directional, leaving the top driver as a true single point source.
Bmotorcycle2003
« Reply #2 on: 8 Aug 2016, 05:49 pm »
There you go, thanks for you quick reply, like I said (LOL) I will leave them alone................
