0 Members and 2 Guests are viewing this topic. Read 56165 times.
No game ,the bass on trio 15b is a lot lot better , plus with fullrange you will have a really good mid/voice, that you can never have with a xover 15" that cross a 1" ,never !!
A generalization and certainly not true with the M3's.The mid's and voices on the M3's are coherent, musical, accurate, and 3D like. I would go as far to say that this is an area of strength of the speaker.George
(sorry Anand but that waveguide is the cone and is not fixed! you forget that little details ..the most important one !)
freemand nice post , we have two really different design , the coax based on an old 50year design ,copy of Tannoy but with cheaper unit ,yes only cheaper unit use a stamped frame , that is crude classic two way xover design with all the problem that all know, Altec have a rich story on coax (sorry Anand but that waveguide is the cone and is not fixed! you forget that little details ..the most important one !) Howerton audio is here from a lot year and serve diy well if you like compression driver or find the original Tannoy gold unit On the other side we have a new concept DIY friendly ,a FAST concept with some full range unit ,no xover in sensible zone or no xover at all if you use biamp with a fantastc 15" aluframe ,neo motor with copper ring .
Do you understand the waveguide Clayton is using?
george I thinks that you dont understand this waveguide !" The Tannoy type takes advantage of the large cone waveguide to provide the horn loading support down to the cone's diameter / wavelength where 15 in diameter = roughly 800Hz support and pattern control bandwidth"
Translation: I've never heard them
You dont know how work ?
English is 2nd language?Inarticulate?Am I the only one who never knows what the hell this guy is saying?
