0 Members and 1 Guest are viewing this topic. Read 11247 times.
Rated power (1% THD + N, 1 kHz) [W] 8 ohms, 2x 100Rated power (1% THD + N, 1 kHz) [W] 4 ohm, 2x 194Sensitivity (for maximum power), [V] 1x 1.0Signal / noise ratio (A-weighted filter with respect to 1W) [dB] 70 The dynamics [dB] 90 The attenuation coefficient (for the 4 ohm) 72
Do not buy it.
They are measurements of Rogue Sphinx, very bad!
You could take that gem of wisdom and say do not buy any tube amplifier on the planet. They are all very bad!
Rated power (1% THD + N, 1 kHz) [W] 8 ohms, 2x 62 Rated power (1% THD + N, 1 kHz) [W] 4 ohm, 2x 109 Sensitivity (for maximum power), [V] 1x 0.47 [maty: acceptable] Signal / noise ratio (A-weighted filter with respect to 1W) [dB] 88 The dynamics [dB] 106 The attenuation coefficient (for the 4 ohm) 75
NAD declared power output 2 x 30 W into 8 ohms. I do not know if I got some other amplifier, but "my" D3020 gave up 66 watts at 8 ohms and 132 watts at 4 ohms. Exactly twofold increase in two times lower impedance! With two channels simultaneously we have 2 x 62 and 2 x 109 W - still great. The sensitivity for the analog input is - lower than the standard - 0.47 V. surprising, especially in a pulsed, low-noise (S / N = 88 dB), the growth rate reaches 106 dB.Limitations can be seen only in the passband (Figure 1), at 10 Hz is still excellent (-0.2 dB) above 10 kHz takes longer decline, but -3 dB point calculated for good 45 kHz. It is noteworthy that no anomaly in terms of the tweeter, which are usually gripe pulse amplifiers.Slightly worse is the distortion spectrum (Fig. 2), the strongest harmonic is the third at -72 dB, and the second is a little lower, at -77 dB, -90 dB level before you see a fifth at -85 dB. Level THD + N less than 0.1% can be achieved only when the output power exceeding 5 W to 8 ohms and 7 to 4 ohms (Fig. 3), consolation we see softer than usual, the area distortion...
I thought the sound was quite good. I wasn't looking at specs when I was listening to the music.
Even without taking into account its affordable price, Rogue Audio's Sphinx offers excellent measured performance with little sign of the usual compromises made in class-D designs. It also has an excellent, moving-magnet–compatible phono stage...
Remember the Sphinx is a $1300 amp, if it sounds pretty good it's a bargain, and reports are it sounds very good, and not just for the money. I too am looking at the amp as it would fit my needs perfectly, i.e. has a good headphone amp and phono amp built in. My question is then since these are the two things that are improved in V2 is it that much better than the 1st model to preclude buying used. I'm thinking yes, but what do you guys think?
I hope to try the amp in my own system in order to get a better picture.
