George,
Can you add a little more description of the Gold Lions? Also, would you mind commenting on noise floor among the tubes you've mentioned? Thank you!
David
Hi David,
I'll chime in as well on this:
- Surprisingly, the stock EH2A3 Gold Grid tubes have the lowest noise / hum out of the ones that I've tried so far in the
LIO DHT PRE circuit. I say "surprisingly" because they certainly are not the most expensive new production 2A3 on the market.
I chose the EH2A3 Gold Grid as the stock tube for the following
4 reasons:
1) Sonically, I found it sits 'right in the middle' and makes for a great starting point and possible final destination tube - detailed but not overly so; rich tone but not too thick/dense/overly saturated; tight fast bass response (but not a tube that bass heads will fall in love with).
2) New production tube, easy to obtain in quantity and at <$100/ea. does not break the bank.
3) Per above - very low noise and hum in our circuit, better in this regard than most other DHT I tried, including quite a few different new production 2A3 and 300B and the more pricey tubes like the EML 2A3 and 300B.
4) Very linear response and high bandwidth in this circuit: 10Hz - 250kHz (+/- 0.5dB) and the -3dB point was close to 500kHz!
Does this mean that the EH2A3 Gold Grid is the one that
you will like the best in your system? Not necessarily. They really
all have a different flavor.
The Gold Lion 300B is also quite good! A little more hum / tube rush than the stock (higher sensitivity speakers will pick up on this
more), and for me, it sits somewhere between the stock EH2A3 and the SV811.
Once I get caught up, I plan to purchase quite a bit more DHTs from different families / brands and report back in more detail. In the meantime, the DHT Tube Tour is rolling forward and hopefully we'll see more impressions from that over the new few weeks.
Sorry I've been so busy! I had no idea that DHT PRE was going to take off like it did (and I've been busy on future projects as well
), but I am thankful for it and really "amped" to read so many positive impressions here and via emails!
Vinnie
