0 Members and 1 Guest are viewing this topic. Read 9550 times.
Is it possible to run the BIT20 on a 15 amp circuit?
No.
Yes it is, you simply need a power cable with a 20A IEC and 15A plug. Easily accommodated by most cable companies.
It makes no sense ...Measure your system current draw. It is ridiculously lower than you think it is. Odds are that a 15 amp product is more than enough.
I have to say looking at audioaficiando site (over the years),there have been lots of no happy customers with ps audio units(just sayin)I have had my Torus(s)for ..................yrs not one problem...end of story ,I could keep going but why???????????? .
The rated to 20 amps conditioner would never even know the wall could only produce 15 amps.. if it never 'asks' for more than ..say ten amps...So I say your 'concern' is 'noted' but of little value.
The 15 amp circuit was in reference to my desktop rig that's upstairs. For my main rig that I'll be building in the future from scratch, I'll likely be getting a 20 amp circuit and that will be drawing more power than my desktop rig. So I would like to future proof it if possible if there aren't any safety issues.
