Trying to mount a tone arm that doesn't really fit
0 Members and 1 Guest are viewing this topic. Read 5014 times.
neobop
  • BIRD LIVES
Re: Trying to mount a tone arm that doesn't really fit
« Reply #20 on: 5 Apr 2016, 03:56 pm »
For an armboard you're almost always safer with a quasi laminate, IMO.  I use epoxy to combine things like acrylic and hardwood ply.   Corian should be a good choice.  I'd put a layer of MDF underneath.  If you vary the ratio of epoxy to hardener,  you can make the glue harder or more compliant.  In this case you might want it a little softer.
neo
ACHiPo
« Reply #21 on: 5 Apr 2016, 08:30 pm »
neo
Good suggestion. :thumb:
BobM
« Reply #22 on: 5 Apr 2016, 10:25 pm »
Or try bonding 2 x 1/2" pieces of Corian together to make a 1" thick armboard.
S Clark
« Reply #23 on: 6 Apr 2016, 11:16 pm »
Motor issue solved.  The Chinese (Jasmine) unit arrived and works fine.  The original is definitely NOT a Jasmine, much heavier and 24V versus 12V.  The tonearm mount moves up the project list by one spot
« Last Edit: 8 Apr 2016, 03:23 am by S Clark »
ACHiPo
« Reply #24 on: 7 Apr 2016, 04:43 am »
Motor issue solved.  The Chinese (Jasmine) unit arrived and works fine.  The original is definitely NOT a Jasmine, much heavier and 24V versus 12V.  The tonearm mount not moves up the project list by one spot
Congrats!
