0 Members and 1 Guest are viewing this topic. Read 9023 times.
Dear folks,I do not well understand the theory of all this, but I do not agree with what is being stated. First of all, I have been in this audiophile game almost 50 years, and I certainly can hear a difference when the switch on an amplifier is thrown, allowing inversion. Francis Baumli
......If you have a speaker with normal drivers, but it has either a port or transmission-line opening at the bottom (let's say either are forward-firing to keep things simple), wouldn't this mean that the information coming out of the port is out of phase with what is coming directly from the drivers up above? After all, the information reaching the bottom is coming off the back of the drivers (primarily), and also there is a time delay caused by the cabinet dimensions which means the sound (compressed air) reaching that opening at the bottom isn't getting down there and out of there as quickly as what is coming from the driver. To my ears a speaker with a port, or with a transmission-line opening, just plain sounds out of phase......
..... To my ears a speaker with a port, or with a transmission-line opening, just plain sounds out of phase. Maybe only slightly, but I am sure I hear it. Or am I hearing something else?........
.... For example, I can hear when a time-alignment between speakers and a sub are off by more than one millisecond.......
And the back wave from the speaker is a motive force from the damping factor of the amp reacting with the magnetic structure of the speaker....
