0 Members and 1 Guest are viewing this topic. Read 9024 times.
First, GG, the ability of a person to detect absolute polarity is the Wood Effect, I can't remember his first name......
......Oh, and I actually did read the first four entire paragraphs of the Wikipedia article on transmission lines. I consider that penance for all sins, both of commission and omission, for my previous 64 years and for any sins in my future.....
Clark Johnsen's book.http://www.amazon.com/Wood-Effect-Unaccounted-Contributor-Confusion/dp/0929383001
Rusty, the wave doesn't start out out of phase, but the extra travel distance certainly adds a time delay - the calculations prove it.
If you have a speaker with normal drivers, but it has either a port or transmission-line opening at the bottom (let's say either are forward-firing to keep things simple), wouldn't this mean that the information coming out of the port is out of phase with what is coming directly from the drivers up above?.......
...... To my ears a speaker with a port, or with a transmission-line opening, just plain sounds out of phase. Maybe only slightly, but I am sure I hear it. Or am I hearing something else? ........
Couple things... as far as sensitivity to phase if you're judging that by placing subwoofers operating up to 180 Hz then yes, most anyone is going to be very sensitive to that. Most people have integration issues with subs running above 80 Hz and after that placement gets more and more critical, but I have head a sub that was "invisible" running at 120 Hz. To me sub frequencies are 50 Hz or less. This isn't nearly the same thing as listening to a full range speaker though...IME very few people are sensitive to the phase shift/group delay in a well designed BR/TL cab, which is generally at very low frequencies. However, it's possible to correct for this using DSP so if you want to hear what a bass cab sounds like with and without correction that's not hard to do. Ultimately, unless you have a very special sensitivity there are far more important things to worry about. But that's why there's a million different speaker designs... everyone has different preferences.
So that is why you won't make the five minute drive across the bridge...
