0 Members and 1 Guest are viewing this topic. Read 13173 times.
Check out the Benchmark DAC2. Very hard to beat at any reasonable price.
The least expensive version of the Benchmark DAC2, the DAC2 L, is $1,695. Even finding one used wouldn't come remotely close to the budget of $500 or less.
Having tried most of the above mentioned dacs my recommendation would go to Wyred 4 Sound DAC-1, should be able to find one for $500 or less.
This might be a good choice. The W4S DAC-1 has a volume control so it can feed your amp directly. No preamp function though.I used my W4S DAC-2 in this mode before adding a turntable with very good results.Todd
Ahem...DAC-1 does NOT have volume control, DAC-2 does.
Hello,I am planning on buying myself a real amp (probably from Odyssey) in the very near future to drive my Sonus Faber Concertinos. My next step will be getting music to it. I will be using a cd player, a turntable (occasionally), and wireless sources like Pandora, Spotify, my iTunes library, and maybe Tidal someday.I am not able to spend a ton of money on this, so leave out anything over $500. Since this is the first time I've really powered my speakers properly, and since I have never used a DAC before, I am sure that anything will be an improvement. While there was some talk of this in my other post, I wanted to make this one focused on DACs.I should mention that I may need a preamp to hook up my sources. So if there are any combos out, that would be good too. I will only have a cd player, and maybe a turntable (not sure because it is a cheap old one).So, let your recommendations fly. I'm ready to do some research.Thanks in advance. Paul
