0 Members and 1 Guest are viewing this topic. Read 13172 times.
Anticipation is right. Don't underestimate the importance of 'break in'. Let the gear get a few hundred hours on it before you make any kind of judgment.
Congratulations. You are now a member of this special club:https://www.youtube.com/watch?v=4NwP3wes4M8
Hi,Congratulations on the new dac. If you really want to hear an improvement try to use better quality audiophile discs if you can which makes a huge difference.Good luck.Cheers Rod
Be grateful your integra was taken out by lightening - using that for music would have been one of the single worst things you could have done. The audiophile gods intervened in your favor! Dacs and tubes need break in. 100hrs for each miminum. DACs do sound best when left on all the time. Not the best with tubes naturally, unless your ok with replacing the tubes every couple of months. Many new 12ax7s are cheap fortunately. Ps BSNode2 has digital volume so can also serve as a preamp.
You're killing me. I do like the looks of the Bluesound, but I really hate to second guess myself (again). It took quite some time to settle on the Jolida. Worse case, I'll sell it someday and switch if I feel the need.
