0 Members and 1 Guest are viewing this topic. Read 17588 times.
My guess is that the new box/port are too big. What were they based on?Someone smarter than me could verify proper box/port size if given the driver parameters.
They may "Bloom" more over time as most full range or "Pro audio" style surround drivers are inherently stiff with low excursion in the first place so some serious hours of break in does help, but likely will never hit super satisfactory depths... You try lining the entire cabinet with foam? Normally this will enhance some output pressure specifically with ports. Otherwise honestly a lot of setups like this it seems need either transmission line cabinets, horn loading cabinets, or active subwoofers to really round them out all the way.
I've had Audio Nirvana 8 inch Supers running in 1.5 cubic foot cabinets for several years. Impressive performance including outstanding bass output. Recently I built 2.8 cubic foot cabinets (with the big 6" port) and tried out the Audio Nirvana 10 inch Classic drivers. While the Classics definitely have improved detail over the Supers, I was quite disappointed that it put out much less bass than the 8's in the smaller cabinet. I've discussed this with Dave at Audio Nirvana who says if anything the 10's in the bigger cabinet should have even stronger bass than the 8's. Anyone have any thoughts on this?
The bass output depends on box size and what stuffing you put inside.What stuffing you put inside this box and how much?
Did you calculate your baffle step loss for your cabinet? Also, did you try to measure the level difference to determine if you were seeing baffle step loss. Bass levels do not magically increase in narrow boxs and must be compensated for just as you did digitally, or with shelf filters to level the response, or filler drivers of equal efficiency to a frequency below the baffle (my preference using two of the same drivers). If you calculate your baffle step loss for your box you might find that your 200 Hz is two low and that you missed some mid bass boost. On an 11-inch wide baffle the baffles step begins at ~600Hz. Some day I will need to try the digital level boost method since it is much cheaper than four drivers.Just a though or two for you to think on with the solution you have in place.Eric
Not a fan of Audio Nirvana cabinet designs (very poorly braced).
80ltr., with a 6in. diameter port you need a tube length of about 10.23in. for an F3 of 49Hz
PS: when you say Super 8 are those the stamped basket or the cast?
