Curious about high-efficiency speakers
0 Members and 1 Guest are viewing this topic. Read 2356 times.
corndog71
  • Some people call me Rob.
« on: 7 Mar 2016, 03:01 pm »
Are there any good high-efficient speakers out there?  For Danny, Have you tried designing a high efficiency speaker?  Any thoughts on this?  I was just curious.
Early B.
Re: Curious about high-efficiency speakers
« Reply #1 on: 7 Mar 2016, 05:24 pm »
jparkhur
« Reply #2 on: 7 Mar 2016, 05:30 pm »
Not sure what the requirement for high efficient is but most of GR's speakers are over 91 db, if you are looking for 95 to 100, there are a few pairs in his stable that would work..
JP
drewm
« Reply #3 on: 7 Mar 2016, 07:16 pm »
Danny's Super-V was 97db
http://gr-research.com/super-v.aspx
Danny's Serenity Acoustics Super-7 was 96db
Danny's LS9 was 91db (but line sources get more efficient as you get farther from them)
http://www.dagogo.com/gr-research-ls9-loudspeaker-review
Danny's x-statik was 91db
http://gr-research.com/x-statikkit.aspx
Danny's N3 was 90.5db
http://gr-research.com/n3-1.aspx
And many many more
corndog71
« Reply #4 on: 7 Mar 2016, 08:30 pm »
I was thinking like 96 and up.  Something that could do well with 2-5 watts of single ended power.
HAL
« Reply #5 on: 7 Mar 2016, 08:44 pm »
You can drive the Super-V's with a low power SET amp.  Depends on how loud you want to get.
Gary's 15wpc PP EL84 battery amps will drive them nicely.
My Pass Labs Aleph2 monoblocks would drive you out of the room if wanted with 100wpc.
Danny Richie
« Reply #6 on: 7 Mar 2016, 09:27 pm »
I still have a pair of V-1's (97db) and a pair of Super-V's (97db) that I really need to do something with. I can make some deals...
ebag4
« Reply #7 on: 8 Mar 2016, 12:51 am »
I drove my V1s with a Bottlehead Stereomour (2A3/3.5watts) to 105db as read on an old RadioShack analog dB meter in a small room, sounded great!  I am currently driving my Wedgies with the same amp although I am building a Bottlehead Kaiju 300B amp.  Keep in mind both of these speakers use the main amp for 200Hz and up, below that the servo amps take over.
Best,
Ed
