What is the best 10" woofer for an OB speaker
0 Members and 2 Guests are viewing this topic. Read 17651 times.
Rich48
« on: 3 Mar 2016, 11:27 pm »
Hi All,
I'm looking for recommendations on what would be the best 10" woofer to use in an open baffel design speaker.  I need the woofer to be at least 92 DB efficient.  It will be used with a Wild Borro Betsy driver and be driven by a 2 watt Decware SET amp. It only needs to get down to around 40 Hz.
Rich
flavo
Re: What is the best 10" woofer for an OB speaker
« Reply #1 on: 4 Mar 2016, 01:20 am »
You'll be driving all 4 drivers with the little SET?
Have you considered a 100w yung plate amp? Affordable and plenty of power.
matevana
« Reply #2 on: 4 Mar 2016, 12:04 pm »
<see below>
matevana
« Reply #3 on: 4 Mar 2016, 12:07 pm »
If you require that kind of efficiency, you may want to take a look at some of the 10" Guitar speakers on the market made by Eminence and Tone Tubby. Some offer alnico magnets, some with hemp based cone material, most with high-ish Qts that many find desirable for OB. Not always the last word in detail or ruler flat response, but if done correctly, can offer a very nice presentation overall. I am running two different sets with only slightly more powerful push-pull tube amps (one EL-34 based and the other 6L6GC) and both sound very nice.
« Reply #4 on: 4 Mar 2016, 12:10 pm »
Correct. I could use one 15'' as Alpha15A in an H frame,
if amp power is small I could use a 100W Class D amp.
nicoch
« Reply #5 on: 9 Apr 2016, 11:26 pm »
you need 6db more of Betsy....ie two alpha15 x side....ie plate amp!
Rich48
« Reply #6 on: 28 Apr 2016, 06:18 pm »
Thanks for all your reply's.  I have decided to use a plate amp to drive the woofers.  So what 10" woofer would work best for adding some bottom to the Betsy's?  I'm using MCM 55-2981 woofers with a Dayton 100 watt plate amp now.  It sounds pretty good but I was wondering if there may be something better out there. I'm looking for tight clean musical base, not room shaking deep base.
« Reply #7 on: 28 Apr 2016, 06:27 pm »
10'' woffer dont work in OB, unless you use alot them.
Instead use one 15'' as Alpha15A.
jparkhur
« Reply #8 on: 28 Apr 2016, 06:32 pm »
Not sure of 10's, but GR Research has some very good (IMO) 8s for OB use.
« Reply #9 on: 28 Apr 2016, 06:40 pm »
Nice speaker, what is the model?
Any xover image?
They not found in the GR site.
jparkhur
« Reply #10 on: 28 Apr 2016, 06:42 pm »
pm
Rich48
« Reply #11 on: 28 Apr 2016, 07:46 pm »
Thanks again for the feedback.  I jumped the gun a little and built my OB's out of some nice curly maple and walnut as a two speaker baffel.  I was hoping not to have to scrap it for better sound.  I get plenty of bass as is but I would like it to be cleaner and more musical. I do have some base traps in the Connors the speakers are facing and I have a QRD defuser behind them.  This gives me a great sound stage and lots of detail.  I really like the Betsy's
Rich48
« Reply #12 on: 28 Apr 2016, 07:58 pm »
I should also mention that the room is very small 9x12, and that I listen at fairly low to moderate volume.
nicoch
« Reply #13 on: 28 Apr 2016, 08:58 pm »
aespeakers are the best , min 12" .
btw if Beta15 is good for Nelson Pass can be good for you too ;)
« Reply #14 on: 28 Apr 2016, 09:44 pm »
The AE Speakers boss are stringent DSP eq most be used, on the other side anyone can buy and use a cheap Alpha15 w/no eq and get satisfactory results.
nicoch
« Reply #15 on: 28 Apr 2016, 10:07 pm »
LO15 or dipole18 don't need dsp ...btw alpha is a winner ;)
but better use 2xside the qts sky rocket if move to much
« Reply #16 on: 28 Apr 2016, 10:11 pm »
When I emailed him to a D15 it was mandatory use DSP.
OBS.: just see the LO15 that is OK at MMS=74g and 93dB, it need a powerful amp though.
nicoch
« Reply #17 on: 29 Apr 2016, 09:56 am »
the LO15 is 4 Ohm , your amp put out volts non W, is 97.55 dB
btw he can take power , you pay for ;)
but only if you have need  higth xo ... two alpha work the same ;)
PS
For that db, I mean work for a non biamp system.
Poultrygeist
« Reply #18 on: 29 Apr 2016, 02:29 pm »
Two Alphas per side wired parallel with a 100 watt Yung plate amp is the cat's meow. Here I'm powering the Alpha's with two Dayton amps but a single Yung is all you need.
Poultrygeist
« Reply #19 on: 29 Apr 2016, 02:39 pm »
Betsy over single Alpha is really quite good but two Alphas per side is mo' better.
