0 Members and 1 Guest are viewing this topic. Read 7811 times.
Space above fire place is 46" wide about 50" high. I want the OLED, but feel it is too small for the space above the fireplace. The 65" will fill the space almost perfectly.
That's because we occasionally hear people wishing their TV's screen was bigger, but rarely hear them wishing their screen was smaller.
Did you mean to say the space is 64" wide, as the 65" TV is 57.39" wide?Steve
Get what you what and don't look back. If your not sure then you'll start doubting yourself every time. Compromise in this scenario is obviously tainted with either cost or other factors. I'd go for the 55". Is this your primary viewing area?
According to a review of the LG65EF9500 Ultra HDTV in the current issue of "Sound and Vision": "As I (and others) have said repeatedly, a 65-inch picture at a normal viewing distance (8.5 feet here) just isn't big enough to clearly show 4K's increased resolution. Today's limited Ultra HD material, including that available for the Sony server, doesn't (yet) include either advanced color HDR (apart from some questionable streamed titles). Both of these features delivered by UHD Blu-Ray will likely produce more eye-popping Ultra HD than plain-vanilla 4K."
What do you like to watch?Sports go with the larger screen 65" and bright picture of LED. Also good if it will be used for gaming, computer, or other content with fixed images that might burn in on the OLED.Movies and you will never regret the added black detail and contrast of the OLED.
Yes, it's primary...I no doubt agree that OLED picture quality is a lot better..just afraid that the size and fit of the TV in the space will look weird and too small for viewing distance, which I can move a foot closer to 10', but looking up at an angle, it's back to 11ft.I can't afford or want to spend $5k on a 65" OLED>
So, are you saying get the smaller OLED?
