0 Members and 1 Guest are viewing this topic. Read 12582 times.
I have used a DL-110 with my Technics SL-1210M5G very successfully. It is HOMC so you don't need a SUT and can use your regular MM phono stage just fine. I don't know for sure, but I think I read somewhere that the DL-103 is not the best match with the standard technics arm. I have never personally tried the DL-103, however.
Thanks! Yeah, I think I'm kinda leaning towards the DL-110, honestly. Are you using 47kohm loading with it? I heard it actually does better with closer to 1k.Also, are you using the stock technics headshell?-Jim
Sorry for the delayed reply, I just saw your post. I have the Vista Audio Phono preamp, so the loading is closer to 10 Kohm. Vista provides a great chart for optimizing loading of its preamp with various carts. Here is the link: http://www.vista-audio.com/products/phono-1mkII/examples.htmAnd yes, I'm using the stock headshell.
The arm is a bit light for a 103. Users say > 20g mass is better. You could use a heavier headshell, but it will work either way. With either of those carts I recommend a Zupreme headshell from LpGear. At $55 it's identical to the Sumiko with azimuth adjustment. You should also beef up the counterweight with that combo. Get it as close to the pivot as convenient. This isn't for mass. It's for tracking. The 103 is an old radio station cart . Fred Flintstone had one installed on Dino's tail. Commonly seen on old arms which could double as a turret on an Abrams tank, it's musicality is high and doesn't overdue it with detail. The 110 is more of an audiofool cart with an HE upgrade from the spherical tipped 103. I had a 160 which was nice. I loaded @ 11K, but it was before I got a Vista. Loading is preamp and user specific.neo
JDUBS, I was wondering how you're liking the Ortofon Quintet Red now that you've spent some time with it? I too have a SL-1200kmII and am thinking about moving into the realm of MC carts.
Just loaned my AU-250 Denon SUT along with a couple of DL-103 carts to a buddy. Denon made SUT's of various prices ( the 250 is BOTL) for decades -still does. Have never been disappointed with one of their SUT's hooked up to one of their cartridges. Same goes for Ortofon's STM-72 used with one of the matching Ortofon very low impedance/very low output carts that match it.But SUT's are in no way universal . I've run DL-103 on SL-1200 and what always seems to happen is eventually the globs of bluetack start to pile up -them washers get bluetacked to the counterweight to make up for all the mass added to the headshell end.DL-103's just keep sounding better the more effective mass they are pushin against -a DL-110 is probably a better mechanical match for the 1200 arm . After going back and forth on the loading for the DL-110 -have decided that I like it best at 47kOhms. Went thru the same process with the DL-102 -decided that on balance - best run into 47kOhm. Sure would like to know what the standard arm for radio playback was for NHK when they and Denon developed the original and still made DL-103 ?
