0 Members and 1 Guest are viewing this topic. Read 9502 times.
I assume you are talking about Watts not RMS Watts, but even so 25 Watts for a 6.5 speaker which you like to call a Subwoofer ..... to a 120 Watt amp is well say it this way not working simple because it can’t.
Actually, it's the manufacturer that calls it a "Subwoofer System". If it is in fact a Yamaha YST-SW012, it contains an 8" driver and a 50W (100W Dynamic Power) amplifier. Yes it's an inexpensive $100 subwoofer, but should be able to add some bass reinforcement within the obvious limitations of its output.I'm also a little unclear as to how the voice coil came to be uncentered and is the "terrible sound" due to the voice coil actually rubbing or is it distorting when being driven beyond its capability?Steve
You are saying it says 5 ohms? I measured the actual speaker to be like 6.4 ohms.
I do not have a copy of the manual on the speakers, let alone the subwoofer. I would love one on each of them.
What is the LFE and all that?
