9B-SST2 power output 120/140
0 Members and 1 Guest are viewing this topic. Read 2183 times.
soundengine355
« on: 16 Feb 2016, 01:54 am »
Hi,
The website lists the 9B-SST2 to have a output of 140/8, however on the back of a unit I spotted the other day it says 120/8. Build date was in 2009.
Has the output been bumped up in 8ohms? If so, what else changed?
srb
Re: 9B-SST2 power output 120/140
« Reply #1 on: 16 Feb 2016, 02:22 am »
The current brochure on the website also says 140W @ 8 ohms, yet the current manual's specification section says 120W @ 8 ohms.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 16 Feb 2016, 02:25 am »
The SST2 increased the power to 140.
james
srb
« Reply #3 on: 16 Feb 2016, 02:44 am »
Then you will want to correct the owner's manual.  The manual on the website labeled "9BSST² Owner's Manual" still says 120W.
soundengine355
« Reply #4 on: 16 Feb 2016, 08:33 am »
Backplate of the unit says 120W/8, not 140W/8, but its a 9B SST2, very confusing.
Is it just a misprint on the rear panel?
soundengine355
« Reply #5 on: 16 Feb 2016, 08:48 am »
« Reply #6 on: 16 Feb 2016, 10:50 am »
Yes it is a misprint - the checkout sheet that comes with the amplifier shows the power on each channel.
james
soundengine355
« Reply #7 on: 16 Feb 2016, 09:17 pm »
Thanks James. Do you have the packaging box dimensions and approx. shipping weight?
« Reply #8 on: 17 Feb 2016, 12:36 am »
Email Mike on that please - [email protected]
james
