0 Members and 1 Guest are viewing this topic. Read 56264 times.
I'd get something with MQA built in.
Take a look:http://positive-feedback.com/audio-discourse/digital-amplifier-company-dac-dac/
I,agree with Tommy. You can have all the toys, knobs, switches and options....but if the sound is not what you're after then you'll be shopping again. DAC DAC abso-freakinlutely nails the sound part of this equation. It's features are pretty focussed on just one thing...Sound. But I found ( and I bought BOTH flavours TL and HS ) that once you hear DAC DAC do its thing on ANY kind of music that I couldn't care less about features. Ferrari buyers don't ask for cup holders! See it here: http://www.cherryamp.com/digital-source
Unfortunately it only inputs coax, so most will have to add a USB/coax converter and coax cable. And compared to many current offerings, it also lacks volume control, multiple inputs, DSD, and headphone amp. All that adds to the price tag and clutter.
Analog volume control can be done fully balanced in the output stage of a DAC without adding anything but a series resistor on each phase and switching resistors between the phases (in between the IV converter and a buffer......totally balanced all the way out). Almost everyone uses a buffer after the IV converter anyway.32 bit digital volume control is built in to ESS Sabre DACs and others. The (scheduled for release in Dec.) Oppo Sonica DAC ($799) and the about to be released in two weeks new Gustard X20U Pro DAC ($899 delivered) both have this feature. The Sonica DAC will have one of the new ESS9038 DAC chips and the Gustard will have two of the new ESS9028 DAC chips. They both have remote controls with volume. The Sonica DAC will have wireless streaming and also usb inputs for hard drives. They both have tons of inputs including a USB DAC input with full DSD256 capability.
So does the DAC DAC use extra bits for volume control?
The DAC DAC has no volume control. I described how to make an extremely seriously transparent volume control balanced. I will say it again. You use a fixed resistor (nude Vishay) in series with each IV converter out. Then, with a switch, you switch .1% resistors between the phases (on the output of the resistors).....then you go to a buffer on each phase and then out. The most transparent volume control in the world? Well, you could use LDRs like what Tortuga does for a smidge better sound. But we are up there in the top 2% anyway. In my opinion........Very interesting stuff!
