diode
0 Members and 1 Guest are viewing this topic. Read 1782 times.
JoshK
diode
« on: 22 Oct 2004, 08:12 pm »
OK, stupid question but what does a diode do?  somehow I can't seem to find the answer to that question.
Occam
diode
« Reply #1 on: 22 Oct 2004, 09:47 pm »
Josh,
Basically, a diode is a one way valve, that only allow electrons to pass one way, from the anode through the cathode, with some 'friction', the voltage drop. [and like any hydraulic valve, if you put too much pressure in the wrong direction, it will blow up] This is a very simplistic explanation. A more definitive explanation (that gives me a headache) -
http://www.epanorama.net/links/componentinfo.html#diode
WerTicus
diode
« Reply #2 on: 23 Oct 2004, 01:42 am »
so whats a soft recovery diode and a fast diode mean? :)
btw that site does not say.
mgalusha
diode
« Reply #3 on: 23 Oct 2004, 03:27 am »
The short answer is they generate less switching noise, reducing EMI. More info can be found here
Lost81
diode
« Reply #4 on: 25 Oct 2004, 04:24 pm »
Speaking of diodes...
Anyone know the specifications of the following model of diode?
Motorola ZP IN 4700 9210
These are the stock models used in the CAL Delta Transport.
I am thinking of of locating hyperfast / ultrafast, soft-recovery diodes to replace them. Maybe the Stealth or HexFRED diodes.
-Lost81
