0 Members and 1 Guest are viewing this topic. Read 7828 times.
Don’t know if your interested but I’ve been thinking of selling my Bel Canto REF 500M Mono amps because they are no longer being used. There in excellent condition and drive my MMG’s with ease. They can be seen in my gallery..Brooklyn
Hi, thanks for the suggestion. Send me a private message with the details and we'll see if it makes sense (I'm going down to a shop tomorrow to listen to the .7....).Jay
Did you like what you heard at that shop? I have a pair of Crown XLS1500s bridged as monoblocks driving my MMGs. No complaints with available power (1,550W Maximum average power in watts at 0.5% THD, 1 kHz!!) but I'm itching to try an "audiophile" amp to see if an upgrade is warranted - Josh358 in another forum was not satisfied with the Crown compared to a Parasound Halo A21, for instance. He found attacks, transients and overall smoothness superior with the 8X more expensive Halo(!).Marc
wasn't able to make the trip due to heavy rain (plan was to ride my motorcycle).... maybe while I'm in Seattle this week visiting my grandson.
One of the better buys out there is the Class D Audio 470C (spring for the upgraded power supply @ $795 all in); one nice feature of the amp is that it has adjustable gain settings, which can certainly come in handy.I've also heard D-Sonics, which are excellent, but almost twice the price of the Class D. They're definitely better than the Class Ds - it just depends on your budget. With the D-Sonic (stereo versions), though, you're into the high $1K low $2K region (depending on the model you choose) – in which case I'd stretch to the Pascal-based Red Dragon S500. Beautifully built, powerful, and refined, especially in the highs. FWIW, if you're on a budget and open to non-Class D, a great and often overlooked option that drives the sh*t out of the Maggies is the Anthem 225 integrated. It's a brute...a very underrated partner. You can often find one used for under $1K, and you won't have to worry about a preamp. Doesn't break a sweat running the Maggies. Good luck!
