0 Members and 1 Guest are viewing this topic. Read 5688 times.
However I'll point out that just low noise isn't that absolute end to the possibilities for audio. I like to add PFC.
Well I suppose if you call something a power conditioner that doesn't in fact have any filtration in it, that's dishonest. But in general most companies do sell a product that's just fine, it's their marketing that's a bit off. People want to read leagues of information when there... just isn't that much to give. So they make up some fluff to say it all strangely and explain some concepts perhaps. The biggest problem with audio, not medical, is that the sound may or may not correlate as being good even when the noise is low. There's plenty of not that well regarded units that would work great in the medical setting.
I doubt they build medical gear under best case scenarios for power. What they are saying there is no power filtration on the med gear. By applying the HYDRA the med gear can now operate better than before with cleaner power.... that is BS. There will be power filtration on that med gear to ensure proper operation of that gear.
