0 Members and 1 Guest are viewing this topic. Read 7472 times.
I have been using a Schiit Bifrost Uber for a couple of years now. Very musical DAC at a great price. I would get that one. Upgrade it later.
Bifrost. But two years ago (approx) I bought the Uber upgrade and installed it myself.
Yes, I like the SBT, but the DAC is mehI use a Schitt Bifrost , way better
thanks for that info.. are you or did you ever use with SBT? and how did the bifrost affect the musical presentation of the SBT?
I use an SB Touch at the moment as a streamer.I am using a Grant Fidelity TubeDAC-11 with it. Installing EDO covers all the hi rez I need (ie up to 24/192 but no DSD etc).The Grant piece would have to be sourced used to hit your budget. I am not giving mine up anytime soon!
My amp is a solid state piece. Class D digital. Crown XLS 1500.
6 hours left on this https://www.massdrop.com/buy/smsl-m8
VERY INTERESTING. have you heard this DAC?tx
I have not, but I watched the first drop at Massdrop, and the very positive reviews - so I am buying one this time. You don't see the Sabre DACs at this price often.
