DAC for squeezebox touch and NAD cd
0 Members and 1 Guest are viewing this topic. Read 7500 times.
srb
Re: DAC for squeezebox touch and NAD cd
« Reply #20 on: 8 Feb 2016, 07:22 pm »
It's a Bifrost.   ;)
Bigfishhk
« Reply #21 on: 8 Feb 2016, 07:46 pm »
I'm surprised you didn't hear much difference between the Squeezebox and Bitfrost Dac. The Touch does have a pleasant sound to it, but it doesn't have the drive and clarity of the Bitfrost in my system. I am running the Uber upgrade.  I will upgrade it to Multibit in the near future.  I the past I have run the Squeezebox through a DIY Chinese Dac with a transformer output which sounded very good.  I also used a Art DI/O dac before that fully modded.   The Schiit Dac sounds better than all of those and represents major bang for buck.  I am running this stuff though a Supratek preamp, Pass labs amp and Eminent Technology speakers and it sounds wonderful.  If you have speakers good enough to resolve the differences between the Touch and and a outboard DAC like the Schiit Bitfrost - go for the outboard DAC.  I haven't played with more expensive Dacs, but I don't feel the need to.
 :D
I have Salk song towers and Rogue 99 tube pre amp and Rogue 100 amp, great sound even with stock SBT. I was surprised but in my system the external DAc made very little difference. sAme with using an Eastern Electric Minimax previously. wIth a laptop and Bifrost I hear huge differences but not with the SBT..  I was surprised by this because my system is pretty revealing. I agree the Bifrost is an exceptional DAC.
mr_bill
« Reply #22 on: 8 Feb 2016, 08:08 pm »
Just spent some time with Schitt Bifrost multibit and the Squeezebox T. After a week's burn in, I did alot of A/B comparison with the Schitt DAc and without it. Very similar results. In many cases I could not distinguish between the two.. which says alot for the actual SQ of the SBT. It surprised me as the Bitfrost is clearly a good piece of kit and would do wonders for a computer..
This is a very interesting comment. Maybe differences in digital are not that great?
Bigfishhk
« Reply #23 on: 9 Feb 2016, 03:25 pm »
in my system they diffrences are not that great. It would be interesting to hear the SBT paired with the very best DAC's..  I used to have a EE minimax Dac plus and it did wonders for playing files via a laptop esp in solid state mode. When I threw the SBT into the system and lost the laptop,  it got much harder to tell the difference so I sold the EE Dac.  Out of curiosity, I would however be interested in hearing a few other DAC's with the SBT, maybe another tube DAC like the Jolida Glass III. If nothing else it looks damn cool!
jarcher
  • It Just Sounds Right
« Reply #24 on: 10 Feb 2016, 12:56 am »
If you're looking for something cheap and more ying to Bifrosts yang, you might give the Micromega Mydac a try. Formally $400, it's now widely available for $250 online. It will definitely sound different than the "meatier" wolfson and akm based dacs. Smoother and bigger soundstage as well.
Bigfishhk
« Reply #25 on: 10 Feb 2016, 02:24 am »
Thanks for the tip. I'll look into that one since it represents something different. And heck it's cheap.
Bigfishhk
« Reply #26 on: 10 Feb 2016, 02:26 am »
- have you heard the Jolida Glass tube dac? I assume it too would add a whole new color to the pciture.
jarcher
« Reply #27 on: 10 Feb 2016, 02:07 pm »
Unfortunately I have not. At that price point I'm not sure it address what you're looking for. Ie tubes might be good for adding body - maybe dimension - to a cheap dac. But seems like your looking for something different from the NAD & Schitt sound and I have a feeling it's going to be more in that direction than different.
Bigfishhk
« Reply #28 on: 10 Feb 2016, 02:39 pm »
Makes sense.. Have you experience with Peachtree Dac-it? I noticed it's on sale for $300 ..
jarcher
« Reply #29 on: 11 Feb 2016, 12:30 am »
Sorry - no direct experience with that peachtree dac. I suspect that it's going to be like the similar AW dragonfly w/ the budget sabre dac chip. Ie maybe better bass and more hard stomping, but the Mydac might be more spacious and refined.
eclein
« Reply #30 on: 11 Feb 2016, 02:29 am »
I use a Aune X1 dac with my sb but I'm saving for the latest AUNE that has Sabre Chip... Like $289 on amazon. https://www.amazon.com/dp/B014FBZCCA/ref=cm_sw_r_awd_2g.UwbTSEX8FC
