0 Members and 1 Guest are viewing this topic. Read 13612 times.
Closest store that sells Magnepan is 4 or 5 hours from me. One disadvantage to autoformers in solid state McIntosh amplifiers is that the power output is the same regardless of output tap...My spl meter indicated volume levels of 112db+ when I was using 30 watts playing though the Martin Logan Spires. I do have to take into account that the Logans had internal 200 watt amplifier driving the 10" woofer which total power comes to 500 watts per side as only the electrostatic panel is driven by the McIntosh amplifier.The loudest volume level in my room was 127 db , at this point meters peaking at 600 watts with the Martin Logan Spires
I have a pair of 1.6's being driven by a Pass Labs X250 amp with 500wpc at 4 ohms. The power meter on the front shows that the the amp rarely if ever leaves its class A operation which is about 25wpc. I have seen the meter occasionally move on thunderous bass at loud levels.
If you have a set of speakers that require X amount of power to play at your preferred SPL, then you procure an amplifier that can supply X amount (or more) of power.This is not complicated. Dave.
Is it a peak or averaging meter?
