0 Members and 1 Guest are viewing this topic. Read 13639 times.
Interesting, thanks. I took a look at that thread and it suggests that the meter doesn't read peaks:"If one does it the way Nelson Pass suggested then there is no need for rectification at all. You just have to care you don't mess up the circuit's properties."I once did it on an ordinary class AB amp (abouit 20 years ago). I simply connected the series connection of a POT and a cheap meter across the emitter resistors of the output stage. No rectification, no filtering (the latter might be beneficial, specially in in my case). What the meter then showed whas the current load on the amp. On a highly biased amp like the X-series amps it is an indicator showing the actual "working area" of the amp. And as already remarked it looks quite cool."A schematic would tell us for sure.
127 db ! I would bet the distortion was peaking with the meters too .....
Yeah that's crazy loud
The math did not add up either, the sensitivity spec was 91dB 2.83volts at 1 meter, a 4 ohm load. 200 watts yields 111dB, 2000 watts = 121db. 600w watts doesn't seem to equal 127dB.Scotty
117dB. I assume it is momentary peaks, otherwise you need to give up on high end audio as you would need hearing aids. As an average measurement this is louder than a typical rock concert. I designed sound systems for clubs at one time and was called on to measure one of them as folks were complaining about ringing ears, etc. It averaged 106 dB C-weighted with dance music. This is mighty loud, people. We had to get it down to about 96-98 dB to stop the complaints. In my 24' x 14' x 8' room I can get to 93-94 dB average with my Maggie 1.6's without clipping with a Jolida 100 x 100 watt tube amp (long wall speaker placement). This is too loud for my ears and will actually cause hearing damage after an hour. At your measured level your ears are toast after 30 seconds, which is the max permitted exposure time for that level according to industrial noise standards. You will experience permanent hearing shift. And no, it will never come back.I see all these posts on AC about Maggies causing amps to clip and I just scratch my head.By the way, in my book, clipping is the most obviously audible form of distortion. This is why I can't listen to most Mapleshade recordings, as they intentionally allow the mic preamps to saturate. I certainly would not want to live next door to you
